Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
  1. Remove all external devices from the computer.
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. Turn off the computer by holding the power button.
    • Turn off the computer by holding the power button.
  3. To remove the battery, slide the left slider on the back to the unlocked position. To remove the battery, slide the left slider on the back to the unlocked position.
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. Push the right slider inwards. Remove the battery out by pulling straight out and to the right.
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. Place the laptop with the back panel facing up and the battery compartment facing away from you. Using a spudger, carefully remove the rubber feet on both sides of the battery compartment.
    • Place the laptop with the back panel facing up and the battery compartment facing away from you.
    • Using a spudger, carefully remove the rubber feet on both sides of the battery compartment.
  6. Using a Phillips #000 screwdriver, remover the ten 7mm screws on the back panel.
    • Using a Phillips #000 screwdriver, remover the ten 7mm screws on the back panel.
    • Using the same screwdriver, remove the two 5mm Phillips #000 screws on both sides of the battery compartment.
  7. With the same orientation as the previous step, locate the bottom left corner.
    • With the same orientation as the previous step, locate the bottom left corner.
    • Using a plastic opening tool, carefully pry off and remove the back panel.
  8. With the back panel removed, orient the laptop with the fan located in the bottom left corner. Locate the Wifi card. Using a Phillips #000 screwdriver, remove the 2mm screw securing the Wifi card in place.
    • With the back panel removed, orient the laptop with the fan located in the bottom left corner.
    • Locate the Wifi card.
    • Using a Phillips #000 screwdriver, remove the 2mm screw securing the Wifi card in place.
    • Carefully remove the Wifi card.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 107
