Ana içeriğe geç
HP 15-ac142dx Motherboard Battery Replacement
Neye ihtiyacın var
  1. HP 15-ac142dx Motherboard Battery Replacement, Motherboard Battery: adım 1, 3 resimden 1. HP 15-ac142dx Motherboard Battery Replacement, Motherboard Battery: adım 1, 3 resimden 2. HP 15-ac142dx Motherboard Battery Replacement, Motherboard Battery: adım 1, 3 resimden 3.
    • Turn off the computer and flip it over onto a flat surface.
    • Remove battery by sliding the battery lock.
    • Remove the 10 screws
  2. HP 15-ac142dx Motherboard Battery Replacement: adım 2, 2 resimden 1. HP 15-ac142dx Motherboard Battery Replacement: adım 2, 2 resimden 2.
    • Flip the computer back over and use the iFixit tool in order to pry the keyboard from the bottom of the computer.
    • Once off you will be able to see the mother board battery.
    • Remove the battery.
    • The battery should be able to be easily removed just by hand
Sonuç
Follow previous instructions in reverse order to reassemble the device .
Bir başkası bu kılavuzu tamamladı.
Nicole Mathieu
620 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G4, Bernier Spring 2018 UMass Dartmouth, Team S2-G4, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S2G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 720
