Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Parçalar
Hiçbir parça belirtilmedi.
  1. The first step you should take is to turn the laptop off.
    • The first step you should take is to turn the laptop off.
    • Next you want to get the prying tool and wedge it into the seam of the screen and outer casing.
  2. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  3. Once it is wedged in on one of the upper corners you want to gently lift and slide the tool down the sides and top of the seam until the frame pops off. Continue moving the tool down, while wedged, to release the grasp. You will be left with just the screen in the casing.
    • Once it is wedged in on one of the upper corners you want to gently lift and slide the tool down the sides and top of the seam until the frame pops off.
    • Continue moving the tool down, while wedged, to release the grasp. You will be left with just the screen in the casing.
    • While prying off make sure you have a good grasp on the computer. You will know it is coming off due to the audible clicks
  4. Next, you will want to unscrew the Phillips PM2.0×5.2 screws at the top of the screen with the #0 bit,  this will allow the screen to pop off easily. Once all the screws are removed, gently remove the screen from the outer casing.
    • Next, you will want to unscrew the Phillips PM2.0×5.2 screws at the top of the screen with the #0 bit, this will allow the screen to pop off easily.
    • Once all the screws are removed, gently remove the screen from the outer casing.
Sonuç
Nicole Mathieu
584 İtibar
5 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team S2-G4, Bernier Spring 2018 UMass Dartmouth, Team S2-G4, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S2G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 239
