Ana içeriğe geç
HP 15-af013cl Front Facing Camera Replacement
Neye ihtiyacın var
  1. HP 15-af013cl Front Facing Camera Replacement, Battery: adım 1, 1 resimden 1.
    • Start off by flipping the laptop on its back.
  2. HP 15-af013cl Front Facing Camera Replacement: adım 2, 3 resimden 1. HP 15-af013cl Front Facing Camera Replacement: adım 2, 3 resimden 2. HP 15-af013cl Front Facing Camera Replacement: adım 2, 3 resimden 3.
    • Push the two spring-loaded tabs inward.
    • Once unlatched, pull the battery out of its compartment.
  3. HP 15-af013cl Front Facing Camera Replacement, Screen: adım 3, 1 resimden 1.
    • Flip the laptop over and have it open as you normally would.
  4. HP 15-af013cl Front Facing Camera Replacement: adım 4, 3 resimden 1. HP 15-af013cl Front Facing Camera Replacement: adım 4, 3 resimden 2. HP 15-af013cl Front Facing Camera Replacement: adım 4, 3 resimden 3.
    • Using a pry tool, unclip the entire outer plastic cover from the front of the screen.
    • Gently remove the front plastic cover.
  5. HP 15-af013cl Front Facing Camera Replacement: adım 5, 1 resimden 1.
    • Remove the two 2.5mm × 3.0mm Phillips screws from each corner of the display.
  6. HP 15-af013cl Front Facing Camera Replacement: adım 6, 2 resimden 1. HP 15-af013cl Front Facing Camera Replacement: adım 6, 2 resimden 2.
    • Carefully lift the display out of the laptop shell and flip it on its front.
    • Disconnect the single cable from the back of the display.
  7. HP 15-af013cl Front Facing Camera Replacement, Front Facing Camera: adım 7, 2 resimden 1. HP 15-af013cl Front Facing Camera Replacement, Front Facing Camera: adım 7, 2 resimden 2.
    • The front camera is held in by light adhesive. Pry gently on the back of the camera in order to remove it.
    • Remove the cable from under the metal foil.
  8. HP 15-af013cl Front Facing Camera Replacement: adım 8, 1 resimden 1.
    • Flip the laptop back over.
    • Using the Phillips P0 screwdriver, remove the 9 M2.5mm x 6.5mm screws from the bottom of the laptop.
    • Remove the additional 2 M2.0mm × 1.5mm Phillips screws located in the battery compartment.
  9. HP 15-af013cl Front Facing Camera Replacement: adım 9, 2 resimden 1. HP 15-af013cl Front Facing Camera Replacement: adım 9, 2 resimden 2.
    • Remove the optical disk drive from the side of the laptop.
  10. HP 15-af013cl Front Facing Camera Replacement: adım 10, 1 resimden 1.
    • Lift off the bottom cover, exposing the motherboard and other components underneath.
  11. HP 15-af013cl Front Facing Camera Replacement: adım 11, 1 resimden 1.
    • Disconnect the display ribbon cable from the motherboard.
Sonuç
Stephen Perreira
787 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S8-G6, Banghart Fall 2017 Cal Poly, Team S8-G6, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S8G6
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 383
