Ana içeriğe geç
HP 15-af013cl Hard Drive Replacement
Neye ihtiyacın var
  1. HP 15-af013cl Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Start off by flipping the laptop on its back.
  2. HP 15-af013cl Hard Drive Replacement: adım 2, 3 resimden 1. HP 15-af013cl Hard Drive Replacement: adım 2, 3 resimden 2. HP 15-af013cl Hard Drive Replacement: adım 2, 3 resimden 3.
    • Push the two spring-loaded tabs inward.
    • Once unlatched, pull the battery out of its compartment.
  3. HP 15-af013cl Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Using the Phillips P0 screwdriver, remove the 9 M2.5mm x 6.5mm screws from the bottom of the laptop.
    • Remove the additional 2 M2.0mm × 1.5mm Phillips screws located in the battery compartment.
  4. HP 15-af013cl Hard Drive Replacement: adım 4, 2 resimden 1. HP 15-af013cl Hard Drive Replacement: adım 4, 2 resimden 2.
    • Remove the optical disk drive from the side of the laptop.
  5. HP 15-af013cl Hard Drive Replacement: adım 5, 2 resimden 1. HP 15-af013cl Hard Drive Replacement: adım 5, 2 resimden 2.
    • Lift off the bottom cover, exposing the motherboard and other components underneath.
    • Unscrew the four Phillips 3.0mm x 3.5mm screws on the hard drive bracket using the PH0 screwdriver.
  6. HP 15-af013cl Hard Drive Replacement: adım 6, 2 resimden 1. HP 15-af013cl Hard Drive Replacement: adım 6, 2 resimden 2.
    • Gently lift the hard drive from its position on the inside of the laptop.
    • Disconnect the ribbon cable from the hard drive.
Sonuç
Stephen Perreira
787 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S8-G6, Banghart Fall 2017 Cal Poly, Team S8-G6, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S8G6
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 1,252
