Ana içeriğe geç
HP 15-af013cl Motherboard Replacement
Neye ihtiyacın var
  1. HP 15-af013cl Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Start off by flipping the laptop on its back.
  2. HP 15-af013cl Motherboard Replacement: adım 2, 3 resimden 1. HP 15-af013cl Motherboard Replacement: adım 2, 3 resimden 2. HP 15-af013cl Motherboard Replacement: adım 2, 3 resimden 3.
    • Push the two spring-loaded tabs inward.
    • Once unlatched, pull the battery out of its compartment.
  3. HP 15-af013cl Motherboard Replacement, Motherboard: adım 3, 1 resimden 1.
    • Using the Phillips P0 screwdriver, remove the nine 2.5mm x 6.5mm screws from the bottom of the laptop.
    • Remove the additional two 2.0mm × 1.5mm Phillips screws located in the battery compartment.
  4. HP 15-af013cl Motherboard Replacement: adım 4, 2 resimden 1. HP 15-af013cl Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the optical disk drive from the side of the laptop.
  5. HP 15-af013cl Motherboard Replacement: adım 5, 1 resimden 1.
    • Lift off the bottom cover, exposing the motherboard and other components underneath.
  6. HP 15-af013cl Motherboard Replacement: adım 6, 2 resimden 1. HP 15-af013cl Motherboard Replacement: adım 6, 2 resimden 2.
    • Begin by removing the 3 Phillips M2.0mm × 10.0mm screws of the processor fan.
    • Disconnect the fan connector from the motherboard.
  7. HP 15-af013cl Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the five Phillips 2.5mm × 6 .5mm screws using the Phillips P0 screwdriver.
  8. HP 15-af013cl Motherboard Replacement: adım 8, 3 resimden 1. HP 15-af013cl Motherboard Replacement: adım 8, 3 resimden 2. HP 15-af013cl Motherboard Replacement: adım 8, 3 resimden 3.
    • Disconnect the ribbon cables for the keyboard, display, trackpad and the various system components.
    • Remove the Wi-Fi card and cables.
  9. HP 15-af013cl Motherboard Replacement: adım 9, 1 resimden 1.
    • Carefully lift out the motherboard from the laptop.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Stephen Perreira
787 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S8-G6, Banghart Fall 2017 Cal Poly, Team S8-G6, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S8G6
5 Üyeler
Bir Yorum
i need motherboard hp model:15-bs127ne
elbetel ashenafi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 1,970
