Ana içeriğe geç
HP 15-af013cl Screen Replacement
Neye ihtiyacın var
  1. HP 15-af013cl Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Start off by flipping the laptop on its back.
  2. HP 15-af013cl Screen Replacement: adım 2, 3 resimden 1. HP 15-af013cl Screen Replacement: adım 2, 3 resimden 2. HP 15-af013cl Screen Replacement: adım 2, 3 resimden 3.
    • Push the two spring-loaded tabs inward.
    • Once unlatched, pull the battery out of its compartment.
  3. HP 15-af013cl Screen Replacement, Screen: adım 3, 1 resimden 1.
    • Flip the laptop over and have it open as you normally would.
  4. HP 15-af013cl Screen Replacement: adım 4, 3 resimden 1. HP 15-af013cl Screen Replacement: adım 4, 3 resimden 2. HP 15-af013cl Screen Replacement: adım 4, 3 resimden 3.
    • Using a pry tool, unclip the entire outer plastic cover from the front of the screen.
    • Gently remove the front plastic cover.
  5. HP 15-af013cl Screen Replacement: adım 5, 1 resimden 1.
    • Remove the two 2.5mm × 3.0mm Phillips screws from each corner of the display.
  6. HP 15-af013cl Screen Replacement: adım 6, 2 resimden 1. HP 15-af013cl Screen Replacement: adım 6, 2 resimden 2.
    • Carefully lift the display out of the laptop shell and flip it on its front.
    • Disconnect the single cable from the back of the display.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stephen Perreira
787 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S8-G6, Banghart Fall 2017 Cal Poly, Team S8-G6, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S8G6
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 1,007
