Ana içeriğe geç
HP 15-af123cl Fan Replacement
Neye ihtiyacın var
  1. HP 15-af123cl Fan Replacement, Battery: adım 1, 2 resimden 1. HP 15-af123cl Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Push the slider with a lock symbol to the right to unlock the battery.
    FixBot'a Sor
    Yorum Ekle
  2. HP 15-af123cl Fan Replacement: adım 2, 1 resimden 1.
    • Push the slider with a battery symbol to the left to push the battery out slightly.
    • Pull the battery out fully now that it is released.
    FixBot'a Sor
    Yorum Ekle
  3. HP 15-af123cl Fan Replacement, Back Cover: adım 3, 1 resimden 1.
    • Remove the twelve screws from the bottom of the laptop using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. HP 15-af123cl Fan Replacement: adım 4, 3 resimden 1. HP 15-af123cl Fan Replacement: adım 4, 3 resimden 2. HP 15-af123cl Fan Replacement: adım 4, 3 resimden 3.
    • Turn the laptop over and open the lid.
    • Use an opening tool to pry the bottom cover from the body of the laptop.
    FixBot'a Sor
    Yorum Ekle
  5. HP 15-af123cl Fan Replacement: adım 5, 2 resimden 1. HP 15-af123cl Fan Replacement: adım 5, 2 resimden 2.
    • Close and turn over the laptop again.
    • Pull the back cover up to remove it from the laptop.
    FixBot'a Sor
    Yorum Ekle
  6. HP 15-af123cl Fan Replacement, Fan: adım 6, 1 resimden 1.
    • Remove all seven screws from the fan and heat sink using a Phillips #000 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. HP 15-af123cl Fan Replacement: adım 7, 1 resimden 1.
    • Remove the heat sink from the laptop.
    FixBot'a Sor
    Yorum Ekle
  8. HP 15-af123cl Fan Replacement: adım 8, 2 resimden 1. HP 15-af123cl Fan Replacement: adım 8, 2 resimden 2.
    • Disconnect the fan cables from the motherboard using an opening tool.
    FixBot'a Sor
    Yorum Ekle
  9. HP 15-af123cl Fan Replacement: adım 9, 1 resimden 1.
    • Remove the fan from the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Victoria Santos
704 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-5, Sinclaire Fall 2021 UMass Dartmouth, Team 2-5, Sinclaire Fall 2021 üyesi
UMASSD-SINCLAIRE-F21S2G5
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 618
