Ana içeriğe geç
HP 15-af123cl Optical Drive Replacement
Neye ihtiyacın var
  1. HP 15-af123cl Optical Drive Replacement, Battery: adım 1, 2 resimden 1. HP 15-af123cl Optical Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Push the slider with a lock symbol to the right to unlock the battery.
  2. HP 15-af123cl Optical Drive Replacement: adım 2, 1 resimden 1.
    • Push the slider with a battery symbol to the left to push the battery out slightly.
    • Pull the battery out fully now that it is released.
  3. HP 15-af123cl Optical Drive Replacement, Optical Drive: adım 3, 2 resimden 1. HP 15-af123cl Optical Drive Replacement, Optical Drive: adım 3, 2 resimden 2.
    • Remove the single screw that holds in the optical drive using a Phillips #00 screwdriver.
  4. HP 15-af123cl Optical Drive Replacement: adım 4, 1 resimden 1.
    • Slide the optical drive out of the laptop.
Sonuç
Victoria Santos
704 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-5, Sinclaire Fall 2021 UMass Dartmouth, Team 2-5, Sinclaire Fall 2021 üyesi
UMASSD-SINCLAIRE-F21S2G5
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 24
Her zaman: 309
