Ana içeriğe geç
HP 15-ay014dx Hard Drive Disk Replacement
Neye ihtiyacın var
  1. HP 15-ay014dx Hard Drive Disk Replacement, Battery: adım 1, 1 resimden 1.
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Hard Drive Disk Replacement: adım 2, 1 resimden 1.
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Hard Drive Disk Replacement: adım 3, 1 resimden 1.
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx Hard Drive Disk Replacement, Optical Drive: adım 4, 1 resimden 1.
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx Hard Drive Disk Replacement: adım 5, 1 resimden 1.
    • Grip the optical drive and gently pull it out.
  6. HP 15-ay014dx Hard Drive Disk Replacement, Hard Drive Disk: adım 6, 2 resimden 1. HP 15-ay014dx Hard Drive Disk Replacement, Hard Drive Disk: adım 6, 2 resimden 2.
    • Remove the highlighted screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  7. HP 15-ay014dx Hard Drive Disk Replacement: adım 7, 3 resimden 1. HP 15-ay014dx Hard Drive Disk Replacement: adım 7, 3 resimden 2. HP 15-ay014dx Hard Drive Disk Replacement: adım 7, 3 resimden 3.
    • Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
    • Pull the back cover off.
  8. HP 15-ay014dx Hard Drive Disk Replacement: adım 8, 3 resimden 1. HP 15-ay014dx Hard Drive Disk Replacement: adım 8, 3 resimden 2. HP 15-ay014dx Hard Drive Disk Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Pry up on the clamp holding the SATA power ribbon using the plastic opening tool.
    • Pull out the SATA power ribbon using the tweezers.
  9. HP 15-ay014dx Hard Drive Disk Replacement: adım 9, 2 resimden 1. HP 15-ay014dx Hard Drive Disk Replacement: adım 9, 2 resimden 2.
    • Remove the highlighted screws holding the hard drive to the body using the Philips #00 screwdriver.
    • Remove the hard drive.
  10. HP 15-ay014dx Hard Drive Disk Replacement: adım 10, 1 resimden 1.
    • Remove the 4 screws holding the hard drive to the hard drive cage using the Philips #00 screwdriver.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Jimmy Huynh
263 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 1,935
