Ana içeriğe geç
HP 15-ay014dx Motherboard Replacement
Neye ihtiyacın var
  1. HP 15-ay014dx Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Motherboard Replacement: adım 2, 1 resimden 1.
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Motherboard Replacement: adım 3, 1 resimden 1.
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx Motherboard Replacement, Optical Drive: adım 4, 1 resimden 1.
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx Motherboard Replacement: adım 5, 1 resimden 1.
    • Grip the optical drive and gently pull it out.
  6. HP 15-ay014dx Motherboard Replacement, RAM: adım 6, 1 resimden 1.
    • Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  7. HP 15-ay014dx Motherboard Replacement: adım 7, 2 resimden 1. HP 15-ay014dx Motherboard Replacement: adım 7, 2 resimden 2.
    • Use the spudger to press the tabs in the back of the computer. Carefully remove the back of the laptop by prying around the sides using the plastic opening tool.
  8. HP 15-ay014dx Motherboard Replacement: adım 8, 2 resimden 1. HP 15-ay014dx Motherboard Replacement: adım 8, 2 resimden 2.
    • Undo the clips holding the RAM in place using the plastic opening tool.
  9. HP 15-ay014dx Motherboard Replacement: adım 9, 1 resimden 1.
    • Carefully pull out the RAM from the motherboard.
  10. HP 15-ay014dx Motherboard Replacement, Hard Drive Disk: adım 10, 2 resimden 1. HP 15-ay014dx Motherboard Replacement, Hard Drive Disk: adım 10, 2 resimden 2.
    • Remove the highlighted screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  11. HP 15-ay014dx Motherboard Replacement: adım 11, 3 resimden 1. HP 15-ay014dx Motherboard Replacement: adım 11, 3 resimden 2. HP 15-ay014dx Motherboard Replacement: adım 11, 3 resimden 3.
    • Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
    • Pull the back cover off.
  12. HP 15-ay014dx Motherboard Replacement: adım 12, 3 resimden 1. HP 15-ay014dx Motherboard Replacement: adım 12, 3 resimden 2. HP 15-ay014dx Motherboard Replacement: adım 12, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Pry up on the clamp holding the SATA power ribbon using the plastic opening tool.
    • Pull out the SATA power ribbon using the tweezers.
  13. HP 15-ay014dx Motherboard Replacement: adım 13, 2 resimden 1. HP 15-ay014dx Motherboard Replacement: adım 13, 2 resimden 2.
    • Remove the highlighted screws holding the hard drive to the body using the Philips #00 screwdriver.
    • Remove the hard drive.
  14. HP 15-ay014dx Motherboard Replacement: adım 14, 1 resimden 1.
    • Remove the 4 screws holding the hard drive to the hard drive cage using the Philips #00 screwdriver.
  15. HP 15-ay014dx Motherboard Replacement, Wireless Card: adım 15, 1 resimden 1.
  16. HP 15-ay014dx Motherboard Replacement: adım 16, 2 resimden 1. HP 15-ay014dx Motherboard Replacement: adım 16, 2 resimden 2.
  17. HP 15-ay014dx Motherboard Replacement: adım 17, 2 resimden 1. HP 15-ay014dx Motherboard Replacement: adım 17, 2 resimden 2.
    • Using the spudger, carefully pry the wire connecting the wireless card to the motherboard off of it.
  18. HP 15-ay014dx Motherboard Replacement: adım 18, 1 resimden 1.
    • Using the size #00 Phillips screwdriver remove the single screw holding it in place.
  19. HP 15-ay014dx Motherboard Replacement: adım 19, 1 resimden 1.
    • carefully pull the card of its slot.
  20. HP 15-ay014dx Motherboard Replacement, Motherboard: adım 20, 3 resimden 1. HP 15-ay014dx Motherboard Replacement, Motherboard: adım 20, 3 resimden 2. HP 15-ay014dx Motherboard Replacement, Motherboard: adım 20, 3 resimden 3.
    • Disconnect all ribbon connectors by flipping up the black tabs and gently pulling them out.
    • Disconnect​ ​the​ ​speakers​ ​by​ ​gently ​pulling​​ ​the​ ​connector ​out.
    • Disconnect​ ​the​ ​Fan​ ​by​ ​gently ​pulling​​ ​the​ ​connector​ ​out.
    • Disconnect the power by gently pulling the connectors out.
  21. HP 15-ay014dx Motherboard Replacement: adım 21, 1 resimden 1.
    • Unscrew the five screws securing the motherboards.
  22. HP 15-ay014dx Motherboard Replacement: adım 22, 1 resimden 1.
    • Gently lift the motherboard up and out of the casing.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Drake Scoville
533 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 24
Her zaman: 1,604
