Ana içeriğe geç
HP 15-ay014dx Optical Drive Replacement
Neye ihtiyacın var
  1. HP 15-ay014dx Optical Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Optical Drive Replacement: adım 2, 1 resimden 1.
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Optical Drive Replacement: adım 3, 1 resimden 1.
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx Optical Drive Replacement, Optical Drive: adım 4, 1 resimden 1.
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx Optical Drive Replacement: adım 5, 1 resimden 1.
    • Grip the optical drive and gently pull it out.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Colton King
227 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 285
