Ana içeriğe geç
HP 15-ay052nr Battery Replacement
    1. HP 15-ay052nr Battery Replacement, Battery: adım 1, 1 resimden 1.
      • To protect the device and yourself, make sure your device is completely powered down before disassembling. Disconnect all external devices before starting any tear down process.
      • Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
      FixBot'a Sor
      Yorum Ekle
    2. HP 15-ay052nr Battery Replacement: adım 2, 1 resimden 1.
      • Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
      • The sliders are located at the back of the device on the side where the display hinges are.
      • The slider closest to the optical drive (CD reader) clicks open but the opposite slider has a spring.
      FixBot'a Sor
      Yorum Ekle
    3. HP 15-ay052nr Battery Replacement: adım 3, 1 resimden 1.
      • Pull the battery slightly up and out to remove.
      • If the battery doesn't pop out, the sliders weren't pushed in far enough. Push the sliders towards the center until the battery pops out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 32
Her zaman: 942
