Ana içeriğe geç
HP 15-ay052nr USB Port Replacement
Neye ihtiyacın var
  1. HP 15-ay052nr USB Port Replacement, Battery: adım 1, 1 resimden 1.
    • To protect the device and yourself, make sure your device is completely powered down before disassembling. Disconnect all external devices before starting any tear down process.
    • Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
  2. HP 15-ay052nr USB Port Replacement: adım 2, 1 resimden 1.
    • Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
    • The sliders are located at the back of the device on the side where the display hinges are.
    • The slider closest to the optical drive (CD reader) clicks open but the opposite slider has a spring.
  3. HP 15-ay052nr USB Port Replacement: adım 3, 1 resimden 1.
    • Pull the battery slightly up and out to remove.
    • If the battery doesn't pop out, the sliders weren't pushed in far enough. Push the sliders towards the center until the battery pops out.
  4. HP 15-ay052nr USB Port Replacement, Bottom Cover: adım 4, 1 resimden 1.
    • Remove the rubber feet on the bottom of the device to access all the screws.
    • There are two rubber feet, one on each side of the battery compartment.
  5. HP 15-ay052nr USB Port Replacement: adım 5, 1 resimden 1.
    • Unscrew the twelve 9 mm JIS #0 screws on the back of the device.
    • Gently remove the optical drive (CD reader) to more easily separate the base.
  6. HP 15-ay052nr USB Port Replacement: adım 6, 1 resimden 1.
    • Unclip the keyboard surface from the base using an iFixit opening tool around the entire border.
  7. HP 15-ay052nr USB Port Replacement: adım 7, 1 resimden 1.
    • Separate the base of the computer from the component assembly.
    • The optical drive can be placed in the base where it corresponds to prevent misplacing it.
  8. HP 15-ay052nr USB Port Replacement, USB Port: adım 8, 1 resimden 1.
    • Remove the three 3mm JIS #0 screws from the hard drive.
  9. HP 15-ay052nr USB Port Replacement: adım 9, 1 resimden 1.
    • Unplug the hard drive and set aside.
  10. HP 15-ay052nr USB Port Replacement: adım 10, 1 resimden 1.
    • Disconnect the cable that is attached to the motherboard from the USB board.
    • The motherboard can be identified as the big blue board in the opposite side of the USB board we are replacing.
  11. HP 15-ay052nr USB Port Replacement: adım 11, 1 resimden 1.
    • Remove the single 3mm JIS #0 screw.
    • Once the screw is out, the USB board can be pulled out for replacement.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 356
