Ana içeriğe geç
HP 15-ay091ms Optical Disk Drive Replacement
Neye ihtiyacın var
  1. HP 15-ay091ms Optical Disk Drive Replacement, Battery: adım 1, 2 resimden 1. HP 15-ay091ms Optical Disk Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Ensure the device is powered off and is disconnected from any AC power supply.
    • Push the latches on either side of the battery down and outward.
    • This unlatches the battery allowing for easy removal.
    • Remove the battery.
  2. HP 15-ay091ms Optical Disk Drive Replacement, Back Panel: adım 2, 3 resimden 1. HP 15-ay091ms Optical Disk Drive Replacement, Back Panel: adım 2, 3 resimden 2. HP 15-ay091ms Optical Disk Drive Replacement, Back Panel: adım 2, 3 resimden 3.
    • Remove the screws from the bottom panel using a JIS #0 screwdriver.
    • Use the iFixit opening pick to lift the back cover from the device.
    • It is helpful to get an opening in one spot of the back cover and carry that opening around the device.
  3. HP 15-ay091ms Optical Disk Drive Replacement, Optical Disk Drive: adım 3, 3 resimden 1. HP 15-ay091ms Optical Disk Drive Replacement, Optical Disk Drive: adım 3, 3 resimden 2. HP 15-ay091ms Optical Disk Drive Replacement, Optical Disk Drive: adım 3, 3 resimden 3.
    • Remove the screws holding the optical drive in place using a JIS #0 screwdriver.
    • Pull the optical disk drive out of its slot.
Sonuç
Jossel Solis
173 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team A-1, Gonzalez Fall 2023 Gateway, Team A-1, Gonzalez Fall 2023 üyesi
GCC-GONZALEZ-F23SAG1
4 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 104
