Ana içeriğe geç
HP 15-ay114cy Screen Replacement
Neye ihtiyacın var
  1. HP 15-ay114cy Screen Replacement, Orient the Laptop: adım 1, 1 resimden 1.
    • Orient the Laptop so the HP logo is facing the table and the battery tabs are accessible.
    • Ensure the laptop is powered off before moving forward.
  2. HP 15-ay114cy Screen Replacement, Push out the Battery: adım 2, 2 resimden 1. HP 15-ay114cy Screen Replacement, Push out the Battery: adım 2, 2 resimden 2.
    • Place your index fingers on each of the two battery holder clips.
    • Using your index fingers, push the battery holder clips inwards (towards the center of the laptop).
  3. HP 15-ay114cy Screen Replacement, Remove the Battery: adım 3, 2 resimden 1. HP 15-ay114cy Screen Replacement, Remove the Battery: adım 3, 2 resimden 2.
    • After the battery clips are pushed in, use either hand to grab hold of the battery.
    • Gently push up to remove the battery.
  4. HP 15-ay114cy Screen Replacement, Remove the Plastic Frame: adım 4, 2 resimden 1. HP 15-ay114cy Screen Replacement, Remove the Plastic Frame: adım 4, 2 resimden 2.
    • Insert the flat end of the plastic opening tool between the screen and plastic frame.
    • Use the plastic opening tool to carefully pry the plastic frame off of the screen, starting in the middle and moving towards the corners.
  5. HP 15-ay114cy Screen Replacement, Remove the Screen: adım 5, 3 resimden 1. HP 15-ay114cy Screen Replacement, Remove the Screen: adım 5, 3 resimden 2. HP 15-ay114cy Screen Replacement, Remove the Screen: adım 5, 3 resimden 3.
    • Use the #00 Phillips-head screwdriver to remove the four 3 mm screws in each corner and carefully detach the screen and lay it onto the keyboard.
  6. HP 15-ay114cy Screen Replacement, Remove the Metal Display Connector: adım 6, 3 resimden 1. HP 15-ay114cy Screen Replacement, Remove the Metal Display Connector: adım 6, 3 resimden 2. HP 15-ay114cy Screen Replacement, Remove the Metal Display Connector: adım 6, 3 resimden 3.
    • Use your thumb and pointer finger to cautiously remove the display connector from the metal frame.
Sonuç
Bradley Evans
613 İtibar
5 adet Kılavuz yazıldı
Ekip
S20S3G#1 S20S3G#1 üyesi
Repair Café
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 303
