Ana içeriğe geç
HP 15-ba0709dx Speakers Replacement
Neye ihtiyacın var
  1. HP 15-ba0709dx Speakers Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch on the left and right side until the battery is detached from its slot.
    • A noticeable pop will be heard when the battery is fully released.
  2. HP 15-ba0709dx Speakers Replacement: adım 2, 1 resimden 1.
    • Pull the battery out of its slot.
    • Be careful not to damage any of the connectors in the process.
  3. HP 15-ba0709dx Speakers Replacement, Back Cover: adım 3, 1 resimden 1.
    • Place the laptop on a clean, flat surface with the bottom side facing up.
  4. HP 15-ba0709dx Speakers Replacement: adım 4, 1 resimden 1.
    • Using a Phillips Head Screwdriver, remove the screws anchoring the bottom casing.
    • Note: Make sure to keep track of the screws once they have been removed.
  5. HP 15-ba0709dx Speakers Replacement: adım 5, 1 resimden 1.
    • Locate the screws about 1 inch from the battery release tabs and use a Phillips Head Screwdriver to remove these screws.
    • Note:Place these newly removed screws with the ones removed in Step 2.
  6. HP 15-ba0709dx Speakers Replacement: adım 6, 2 resimden 1. HP 15-ba0709dx Speakers Replacement: adım 6, 2 resimden 2.
    • Locate the rubber friction pads on the top corners of the laptop. Pry the pads from the laptop and place them off to the side
    • Removing the friction pads will reveal two more anchoring screws.
    • Note: The adhesive keeping the pads on the laptop will weaken once doing this, but it is necessary to removing the bottom cover of the laptop.
  7. HP 15-ba0709dx Speakers Replacement: adım 7, 1 resimden 1.
    • Remove disc reader.
    • Note: If all screws are removed it should slide out easily.
  8. HP 15-ba0709dx Speakers Replacement: adım 8, 2 resimden 1. HP 15-ba0709dx Speakers Replacement: adım 8, 2 resimden 2.
    • Use a plastic prod to pry the back cover off the laptop.
    • Be careful not to damage the laptop while prying.
  9. HP 15-ba0709dx Speakers Replacement, Speakers: adım 9, 2 resimden 1. HP 15-ba0709dx Speakers Replacement, Speakers: adım 9, 2 resimden 2.
    • Locate the speakers on the right and left on the bottom on the back of the device.
  10. HP 15-ba0709dx Speakers Replacement: adım 10, 1 resimden 1.
    • Pull up on the left speaker to pop it off.
    • Do the same on the right speaker to pop it off.
  11. HP 15-ba0709dx Speakers Replacement: adım 11, 2 resimden 1. HP 15-ba0709dx Speakers Replacement: adım 11, 2 resimden 2.
    • Pull out the speaker outlet.
    • Caution: Be careful not to damage cords while doing so.
Sonuç
Reece Marr
369 İtibar
3 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S13-G3, Bennett Spring 2017 Texas Tech, Team S13-G3, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S13G3
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 340
