Ana içeriğe geç
HP 15-bs051od Screen Replacement
Neye ihtiyacın var
  1. HP 15-bs051od Screen Replacement, RAM: adım 1, 1 resimden 1.
    • Start with the laptop face down.
    • Remove the eight 6 mm Phillips head screws securing the lower case.
    FixBot'a Sor
    Yorum Ekle
  2. HP 15-bs051od Screen Replacement: adım 2, 2 resimden 1. HP 15-bs051od Screen Replacement: adım 2, 2 resimden 2.
    • Use the opening tool to pry the lower case away from the body of the laptop.
    • Remove the lower case.
    FixBot'a Sor
    Yorum Ekle
  3. HP 15-bs051od Screen Replacement: adım 3, 3 resimden 1. HP 15-bs051od Screen Replacement: adım 3, 3 resimden 2. HP 15-bs051od Screen Replacement: adım 3, 3 resimden 3.
    • Pull the RAM-retaining arms away from the RAM chip.
    • The RAM chip should slightly "pop" up from it's socket.
    FixBot'a Sor
    Yorum Ekle
  4. HP 15-bs051od Screen Replacement: adım 4, 2 resimden 1. HP 15-bs051od Screen Replacement: adım 4, 2 resimden 2.
    • Pull the RAM chip out of its socket.
    • Our device does not specifically have a second RAM chip, but make sure to remove the second RAM chip below the first RAM chip.
    • Repeat this process for the second RAM chip.
    FixBot'a Sor
    Yorum Ekle
  5. HP 15-bs051od Screen Replacement, Motherboard: adım 5, 3 resimden 1. HP 15-bs051od Screen Replacement, Motherboard: adım 5, 3 resimden 2. HP 15-bs051od Screen Replacement, Motherboard: adım 5, 3 resimden 3.
    • Remove the four (4 mm) Phillips screws on the heatsink.
    • Remove the exhaust by carefully lifting it up.
    FixBot'a Sor
    Yorum Ekle
  6. HP 15-bs051od Screen Replacement: adım 6, 1 resimden 1.
    • Disconnect the connecting cable of the fan and remove the fan.
    FixBot'a Sor
    Yorum Ekle
  7. HP 15-bs051od Screen Replacement: adım 7, 2 resimden 1. HP 15-bs051od Screen Replacement: adım 7, 2 resimden 2.
    • Pull the red, white, black, and blue cable directly out of its port.
    FixBot'a Sor
    Yorum Ekle
  8. HP 15-bs051od Screen Replacement: adım 8, 1 resimden 1.
    • Slide the left speaker out.
    FixBot'a Sor
    Yorum Ekle
  9. HP 15-bs051od Screen Replacement: adım 9, 1 resimden 1.
    • Pull the black and red cable connecting both speakers out of its secure fastening.
    FixBot'a Sor
    Yorum Ekle
  10. HP 15-bs051od Screen Replacement: adım 10, 1 resimden 1.
    • Pull the right speaker out by sliding from left to right.
    FixBot'a Sor
    Yorum Ekle
  11. HP 15-bs051od Screen Replacement: adım 11, 2 resimden 1. HP 15-bs051od Screen Replacement: adım 11, 2 resimden 2.
    • Locate the motherboard.
    • The motherboard is the biggest blue-colored surface located inside the computer.
    • Locate the six ribbon cables.
    FixBot'a Sor
    Yorum Ekle
  12. HP 15-bs051od Screen Replacement: adım 12, 2 resimden 1. HP 15-bs051od Screen Replacement: adım 12, 2 resimden 2.
    • Flip up the ZIF lock bars that keep the six ribbon cables in place.
    • Slide the rest of the ribbon cables out of their fastenings.
    FixBot'a Sor
    Yorum Ekle
  13. HP 15-bs051od Screen Replacement: adım 13, 2 resimden 1. HP 15-bs051od Screen Replacement: adım 13, 2 resimden 2.
    • Remove the four (4 mm) Phillips screws securing the motherboard.
    FixBot'a Sor
    Yorum Ekle
  14. HP 15-bs051od Screen Replacement: adım 14, 2 resimden 1. HP 15-bs051od Screen Replacement: adım 14, 2 resimden 2.
    • Remove the single (4 mm) Phillips screw on the Wi-Fi card.
    • Slide the Wi-Fi card out of its port.
    FixBot'a Sor
    Yorum Ekle
  15. HP 15-bs051od Screen Replacement: adım 15, 2 resimden 1. HP 15-bs051od Screen Replacement: adım 15, 2 resimden 2.
    • Unfasten the connecting cable.
    FixBot'a Sor
    Yorum Ekle
  16. HP 15-bs051od Screen Replacement: adım 16, 2 resimden 1. HP 15-bs051od Screen Replacement: adım 16, 2 resimden 2.
    • Remove the display cable.
    FixBot'a Sor
    Yorum Ekle
  17. HP 15-bs051od Screen Replacement: adım 17, 1 resimden 1.
    • Lift up the motherboard.
    FixBot'a Sor
    Yorum Ekle
  18. HP 15-bs051od Screen Replacement, Screen: adım 18, 1 resimden 1.
    • Remove the following Phillips screws:
    • Five 7 mm screws on the display hinge.
    • One 3 mm screw.
    FixBot'a Sor
    Yorum Ekle
  19. HP 15-bs051od Screen Replacement: adım 19, 1 resimden 1.
    • Partially open the laptop and remove the base.
    FixBot'a Sor
    Yorum Ekle
  20. HP 15-bs051od Screen Replacement: adım 20, 2 resimden 1. HP 15-bs051od Screen Replacement: adım 20, 2 resimden 2.
    • Use the opening tool to carefully separate the screen cover from the screen.
    • Use the opening tool to carefully remove the adhesive screen bezel from around the screen.
    FixBot'a Sor
    Yorum Ekle
  21. HP 15-bs051od Screen Replacement: adım 21, 1 resimden 1.
    • Two 4 mm screws from the top of the screen.
    • Two 4 mm from the bottom of the screen.
    FixBot'a Sor
    Yorum Ekle
  22. HP 15-bs051od Screen Replacement: adım 22, 1 resimden 1.
    • Carefully lift the screen from the display assembly without disconnecting the display cable.
    FixBot'a Sor
    Yorum Ekle
  23. HP 15-bs051od Screen Replacement: adım 23, 1 resimden 1.
    • Remove the display cable from the back of the screen.
    FixBot'a Sor
    Yorum Ekle
  24. HP 15-bs051od Screen Replacement: adım 24, 1 resimden 1.
    • Remove the screen from the display assembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Kaz Furtado
148 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-1, Botvin Spring 2023 UMass Dartmouth, Team 6-1, Botvin Spring 2023 üyesi
UMASSD-BOTVIN-S23S6G1
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 42
Her zaman: 503
