Giriş
This guide will show you how to find your RAM and how to remove it properly. To determine that the RAM is the source of your issue, make sure to troubleshoot first by following the steps listed here and here. To replace faulty or corrupt RAM or upgrade the RAM capacity on your laptop, follow this guide.
Neye ihtiyacın var
Use a Phillips #0 screwdriver to remove the six 10.5 mm screws visible on the bottom of the laptop.
Bu adımda kullanılan alet:Plastic Cards$2.99
Flip the laptop over and open the screen.
Carefully use a flat plastic card to separate the bottom plastic shell from the main body of the computer. Slowly slide the plastic card around the computer in between the two halves of its casing.
Flip the computer back over and remove the bottom plastic shell.
3 farklı kişi bu kılavuzu tamamladı.
