Ana içeriğe geç
HP 15-d076nr RAM Replacement
Neye ihtiyacın var
  1. HP 15-d076nr RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Orient the laptop upside down so that the back of the laptop, where the battery is located, faces away from you.
    FixBot'a Sor
    Yorum Ekle
  2. HP 15-d076nr RAM Replacement: adım 2, 1 resimden 1.
    • Locate the small screw on the panel at the center of the laptop.
    • Loosen the small screw using a Philips # 1 screwdriver.
    • The screw does not come free from the panel. It only needs to be loosened enough so that the panel can be lifted/pried.
    FixBot'a Sor
    Yorum Ekle
  3. HP 15-d076nr RAM Replacement: adım 3, 2 resimden 1. HP 15-d076nr RAM Replacement: adım 3, 2 resimden 2.
    • Carefully pry the middle panel up using a plastic spudger or other prying tool .
    • Pull the panel away from the laptop and set it off to the side.
    FixBot'a Sor
    Yorum Ekle
  4. HP 15-d076nr RAM Replacement: adım 4, 1 resimden 1.
    • Locate the RAM in the exposed area.
    FixBot'a Sor
    Yorum Ekle
  5. HP 15-d076nr RAM Replacement: adım 5, 3 resimden 1. HP 15-d076nr RAM Replacement: adım 5, 3 resimden 2. HP 15-d076nr RAM Replacement: adım 5, 3 resimden 3.
    • Locate the latches on the RAM.
    • Slide the latches away from the RAM using a plastic spudger.
    • The RAM might spring out.
    FixBot'a Sor
    Yorum Ekle
  6. HP 15-d076nr RAM Replacement: adım 6, 1 resimden 1.
    • Remove the RAM.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Amy Weed
577 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 24
Her zaman: 790
