Ana içeriğe geç
HP 15-d076nr Wireless Card Replacement
Neye ihtiyacın var
  1. HP 15-d076nr Wireless Card Replacement, Battery: adım 1, 1 resimden 1.
    • Orient the laptop upside down so that the back of the laptop, where the battery is located, faces you.
    • Locate the left and right switches at the bottom of the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. HP 15-d076nr Wireless Card Replacement: adım 2, 1 resimden 1.
    • Move the right switch to the left so that the orange unlock symbol is showing.
    FixBot'a Sor
    Yorum Ekle
  3. HP 15-d076nr Wireless Card Replacement: adım 3, 1 resimden 1.
    • Move the left switch to the right, covering the battery symbol, and hold.
    FixBot'a Sor
    Yorum Ekle
  4. HP 15-d076nr Wireless Card Replacement: adım 4, 1 resimden 1.
    • While holding the left switch in place, slide the battery towards you and away from the laptop.
    FixBot'a Sor
    Yorum Ekle
  5. HP 15-d076nr Wireless Card Replacement, Wireless Card: adım 5, 1 resimden 1.
    • Re-orient the laptop, so that the back of the laptop faces away from you.
    FixBot'a Sor
    Yorum Ekle
  6. HP 15-d076nr Wireless Card Replacement: adım 6, 1 resimden 1.
    • Locate the small screw on the panel at the center of the laptop.
    • Loosen the small screw using a Philips # 1 screwdriver.
    • The screw does not come free from the panel. It only needs to be loosened enough so that the panel can be lifted/pried.
    FixBot'a Sor
    Yorum Ekle
  7. HP 15-d076nr Wireless Card Replacement: adım 7, 2 resimden 1. HP 15-d076nr Wireless Card Replacement: adım 7, 2 resimden 2.
    • Carefully pry the middle panel up using a plastic spudger, or other prying tool .
    • Pull the panel away from the laptop and set it off to the side.
    FixBot'a Sor
    Yorum Ekle
  8. HP 15-d076nr Wireless Card Replacement: adım 8, 2 resimden 1. HP 15-d076nr Wireless Card Replacement: adım 8, 2 resimden 2.
    • Gently wiggle and lift the black antenna wire away from the wireless card.
    • If there is also a white wire attached, both black and white wires will need to be removed from the wireless card.
    FixBot'a Sor
    Yorum Ekle
  9. HP 15-d076nr Wireless Card Replacement: adım 9, 3 resimden 1. HP 15-d076nr Wireless Card Replacement: adım 9, 3 resimden 2. HP 15-d076nr Wireless Card Replacement: adım 9, 3 resimden 3.
    • Locate the Phillips 2.0x3.0mm screw on the upper left corner of the wireless card.
    • Carefully remove the 2.0x3.0mm screw using a Philips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  10. HP 15-d076nr Wireless Card Replacement: adım 10, 1 resimden 1.
    • Slide the wireless card to the left to remove it from the socket.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 780
