Ana içeriğe geç
HP 15-da0002dx RAM Replacement
Neye ihtiyacın var
  1. HP 15-da0002dx RAM Replacement, Back Cover: adım 1, 1 resimden 1.
    • Make sure the computer is completely turned off.
  2. HP 15-da0002dx RAM Replacement: adım 2, 1 resimden 1.
    • Turn over the laptop.
    • The HP label should be touching the table and the bottom cover should be facing up.
  3. HP 15-da0002dx RAM Replacement: adım 3, 2 resimden 1. HP 15-da0002dx RAM Replacement: adım 3, 2 resimden 2.
    • Two plastic feet are located on adjacent sides of the back cover.
    • Peel back the plastic feet using the plastic opening tools.
  4. HP 15-da0002dx RAM Replacement: adım 4, 1 resimden 1.
    • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
  5. HP 15-da0002dx RAM Replacement: adım 5, 1 resimden 1.
    • Carefully flip over the computer so the HP label is now facing the ceiling.
  6. HP 15-da0002dx RAM Replacement: adım 6, 2 resimden 1. HP 15-da0002dx RAM Replacement: adım 6, 2 resimden 2.
    • Open the screen.
    • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
  7. HP 15-da0002dx RAM Replacement: adım 7, 1 resimden 1.
    • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
  8. HP 15-da0002dx RAM Replacement, Battery: adım 8, 1 resimden 1.
    • Remove the screws holding the battery in place using a Phillips #1 screwdriver.
  9. HP 15-da0002dx RAM Replacement: adım 9, 2 resimden 1. HP 15-da0002dx RAM Replacement: adım 9, 2 resimden 2.
    • Using your fingers, tilt the top part of the battery towards you.
    • Continue to pull the rest of the battery away from the mounting tabs to remove.
  10. HP 15-da0002dx RAM Replacement, RAM: adım 10, 1 resimden 1.
    • The retention clips are located on either side of the RAM module. Spread them away from each other until you hear a clicking sound.
  11. HP 15-da0002dx RAM Replacement: adım 11, 2 resimden 1. HP 15-da0002dx RAM Replacement: adım 11, 2 resimden 2.
    • Pull the RAM module away from the slot.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Abigail Aron
941 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 1,256
