Ana içeriğe geç
HP 15-da0012dx Battery Replacement
Neye ihtiyacın var
  1. HP 15-da0012dx Battery Replacement, Battery: adım 1, 2 resimden 1. HP 15-da0012dx Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Power down your laptop before proceeding.
    • Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
  2. HP 15-da0012dx Battery Replacement: adım 2, 3 resimden 1. HP 15-da0012dx Battery Replacement: adım 2, 3 resimden 2. HP 15-da0012dx Battery Replacement: adım 2, 3 resimden 3.
    • Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
  3. HP 15-da0012dx Battery Replacement: adım 3, 2 resimden 1. HP 15-da0012dx Battery Replacement: adım 3, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
  4. HP 15-da0012dx Battery Replacement: adım 4, 2 resimden 1. HP 15-da0012dx Battery Replacement: adım 4, 2 resimden 2.
    • Slide the optical drive out of the computer.
  5. HP 15-da0012dx Battery Replacement: adım 5, 3 resimden 1. HP 15-da0012dx Battery Replacement: adım 5, 3 resimden 2. HP 15-da0012dx Battery Replacement: adım 5, 3 resimden 3.
    • Flip the computer over and open the screen.
    • Start from a corner and run the plastic opening tools along the edge of the back cover.
    • After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
    • Gently pry back the cover starting from the middle, bottom edge.
    • Make sure not to bend or crack the plastic cover.
  6. HP 15-da0012dx Battery Replacement: adım 6, 2 resimden 1. HP 15-da0012dx Battery Replacement: adım 6, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
  7. HP 15-da0012dx Battery Replacement: adım 7, 2 resimden 1. HP 15-da0012dx Battery Replacement: adım 7, 2 resimden 2.
    • Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Xavier Hung
914 İtibar
4 adet Kılavuz yazıldı
Ekip
UC Davis, Team S20-G4, Lore Winter 2019 UC Davis, Team S20-G4, Lore Winter 2019 üyesi
UCD-LORE-W19S20G4
3 Üyeler
7 adet Kılavuz yazıldı
4 Yorum
Where to find, buy the same battery.
Divya Lekha - Yanıt
Where r living. We can help you which website you buy this battery
Mahima Singh -
Thank you for the guide! =D
Kevin - Yanıt
If you are living in Delhi ncr. We provide him service and delivery of hp ht03xl battery at very reasonable price at your office and home. Our home service executive will help you to assemble this battery. Nice description details about here. How to replace hp original battery.
Mahima Singh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 36
Son 30 gün: 159
Her zaman: 13,408
