Ana içeriğe geç
HP 15-da0012dx SSD Replacement
Neye ihtiyacın var
  1. HP 15-da0012dx SSD Replacement, Battery: adım 1, 2 resimden 1. HP 15-da0012dx SSD Replacement, Battery: adım 1, 2 resimden 2.
    • Power down your laptop before proceeding.
    • Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
  2. HP 15-da0012dx SSD Replacement: adım 2, 3 resimden 1. HP 15-da0012dx SSD Replacement: adım 2, 3 resimden 2. HP 15-da0012dx SSD Replacement: adım 2, 3 resimden 3.
    • Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
  3. HP 15-da0012dx SSD Replacement: adım 3, 2 resimden 1. HP 15-da0012dx SSD Replacement: adım 3, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
  4. HP 15-da0012dx SSD Replacement: adım 4, 2 resimden 1. HP 15-da0012dx SSD Replacement: adım 4, 2 resimden 2.
    • Slide the optical drive out of the computer.
  5. HP 15-da0012dx SSD Replacement: adım 5, 3 resimden 1. HP 15-da0012dx SSD Replacement: adım 5, 3 resimden 2. HP 15-da0012dx SSD Replacement: adım 5, 3 resimden 3.
    • Flip the computer over and open the screen.
    • Start from a corner and run the plastic opening tools along the edge of the back cover.
    • After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
    • Gently pry back the cover starting from the middle, bottom edge.
    • Make sure not to bend or crack the plastic cover.
  6. HP 15-da0012dx SSD Replacement: adım 6, 2 resimden 1. HP 15-da0012dx SSD Replacement: adım 6, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
  7. HP 15-da0012dx SSD Replacement: adım 7, 2 resimden 1. HP 15-da0012dx SSD Replacement: adım 7, 2 resimden 2.
    • Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
  8. HP 15-da0012dx SSD Replacement, SSD: adım 8, 2 resimden 1. HP 15-da0012dx SSD Replacement, SSD: adım 8, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the single 3.0 mm screw holding the SSD module in place.
  9. HP 15-da0012dx SSD Replacement: adım 9, 2 resimden 1. HP 15-da0012dx SSD Replacement: adım 9, 2 resimden 2.
    • Pull the SSD module away from the socket.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Xavier Hung
914 İtibar
4 adet Kılavuz yazıldı
Ekip
UC Davis, Team S20-G4, Lore Winter 2019 UC Davis, Team S20-G4, Lore Winter 2019 üyesi
UCD-LORE-W19S20G4
3 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Nice explanation about how to disassemble of hp laptop and assembly of SSD again in this video. Thanks this help me a lot. If you need assistance in Delhi ncr. Kindly call us
Mahima Singh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 25
Son 30 gün: 65
Her zaman: 8,617
