Ana içeriğe geç
HP 15-da0012dx Screen Replacement
Neye ihtiyacın var
  1. HP 15-da0012dx Screen Replacement, Battery: adım 1, 2 resimden 1. HP 15-da0012dx Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Power down your laptop before proceeding.
    • Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
  2. HP 15-da0012dx Screen Replacement: adım 2, 3 resimden 1. HP 15-da0012dx Screen Replacement: adım 2, 3 resimden 2. HP 15-da0012dx Screen Replacement: adım 2, 3 resimden 3.
    • Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
  3. HP 15-da0012dx Screen Replacement: adım 3, 2 resimden 1. HP 15-da0012dx Screen Replacement: adım 3, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
  4. HP 15-da0012dx Screen Replacement: adım 4, 2 resimden 1. HP 15-da0012dx Screen Replacement: adım 4, 2 resimden 2.
    • Slide the optical drive out of the computer.
  5. HP 15-da0012dx Screen Replacement: adım 5, 3 resimden 1. HP 15-da0012dx Screen Replacement: adım 5, 3 resimden 2. HP 15-da0012dx Screen Replacement: adım 5, 3 resimden 3.
    • Flip the computer over and open the screen.
    • Start from a corner and run the plastic opening tools along the edge of the back cover.
    • After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
    • Gently pry back the cover starting from the middle, bottom edge.
    • Make sure not to bend or crack the plastic cover.
  6. HP 15-da0012dx Screen Replacement: adım 6, 2 resimden 1. HP 15-da0012dx Screen Replacement: adım 6, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
  7. HP 15-da0012dx Screen Replacement: adım 7, 2 resimden 1. HP 15-da0012dx Screen Replacement: adım 7, 2 resimden 2.
    • Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
  8. HP 15-da0012dx Screen Replacement, Screen: adım 8, 2 resimden 1. HP 15-da0012dx Screen Replacement, Screen: adım 8, 2 resimden 2.
    • Remove the 3 mm Phillips #0 screw securing the WLAN card in place.
    • Carefully remove the WLAN card from the motherboard.
    • Gently remove the antenna cable from the wire guides in the speaker and chassis.
    • Place WLAN card off to the side being careful not to pull on the antenna cable.
    • The antenna cable is soft and can easily be damaged.
  9. HP 15-da0012dx Screen Replacement: adım 9, 3 resimden 1. HP 15-da0012dx Screen Replacement: adım 9, 3 resimden 2. HP 15-da0012dx Screen Replacement: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Carefully use the metal tweezers to remove the display connection to the motherboard.
  10. HP 15-da0012dx Screen Replacement: adım 10, 3 resimden 1. HP 15-da0012dx Screen Replacement: adım 10, 3 resimden 2. HP 15-da0012dx Screen Replacement: adım 10, 3 resimden 3.
    • Use the Phillips #1 screwdriver to disconnect the display hinges from the base of the laptop.
  11. HP 15-da0012dx Screen Replacement: adım 11, 2 resimden 1. HP 15-da0012dx Screen Replacement: adım 11, 2 resimden 2.
    • Making sure to hold both the base and the screen, partially open laptop.
    • Carefully remove screen from laptop, making sure that the WLAN card is safely removed with it.
  12. HP 15-da0012dx Screen Replacement: adım 12, 3 resimden 1. HP 15-da0012dx Screen Replacement: adım 12, 3 resimden 2. HP 15-da0012dx Screen Replacement: adım 12, 3 resimden 3.
    • Carefully use the pry tool to separate the screen side of the hinge cover from the screen.
    • Rotate the hinge cover away from the screen to remove it from the screen.
  13. HP 15-da0012dx Screen Replacement: adım 13, 3 resimden 1. HP 15-da0012dx Screen Replacement: adım 13, 3 resimden 2. HP 15-da0012dx Screen Replacement: adım 13, 3 resimden 3.
    • Starting from the area near the hinges, gently remove the adhesive display bezel from around the screen using the iFixit opening tool.
  14. HP 15-da0012dx Screen Replacement: adım 14, 2 resimden 1. HP 15-da0012dx Screen Replacement: adım 14, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove the four 3.0 mm screws securing the screen to the top cover.
  15. HP 15-da0012dx Screen Replacement: adım 15, 2 resimden 1. HP 15-da0012dx Screen Replacement: adım 15, 2 resimden 2.
    • Carefully lift the screen, being aware to not pull on the display cable connecting the screen to the top cover.
    • Gently remove the display cable from the back of the screen.
    • Remove the screen from the display assembly.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 38
Her zaman: 3,485
