Ana içeriğe geç
HP 15-db0015dx Battery Replacement
Neye ihtiyacın var
  1. HP 15-db0015dx Battery Replacement, Battery: adım 1, 2 resimden 1. HP 15-db0015dx Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Power off the device before starting.
    • Remove the rubber strips that hide the screws using the spudger.
    • Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
  2. HP 15-db0015dx Battery Replacement: adım 2, 3 resimden 1. HP 15-db0015dx Battery Replacement: adım 2, 3 resimden 2. HP 15-db0015dx Battery Replacement: adım 2, 3 resimden 3.
    • Use the spudger tool to pry open the back cover.
    • Lift the back panel to access the inside.
    • Slide the CD drive to the left, and remove.
  3. HP 15-db0015dx Battery Replacement: adım 3, 3 resimden 1. HP 15-db0015dx Battery Replacement: adım 3, 3 resimden 2. HP 15-db0015dx Battery Replacement: adım 3, 3 resimden 3.
    • Unscrew the three battery screws with a Phillips #0 screwdriver.
    • Lift the battery up, disconnecting the connector first.
    • Push forward and remove the battery.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Dobrej schanim zakladovou desku na HP Pavilion 15-db005dx Palmrest ,
Mohli bysta mi poradit kde ji koupim predem dekuji za odpoved.
jiri Zavurka - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 18
Son 30 gün: 122
Her zaman: 7,086
