Giriş
The hard drive archives data you want to store in your computer, weather it’s automated logs or your vacation photos. This guide will teach you how to replace the hard drive in your HP 15-db0015dx should you want an upgrade or a replacement. If you experience errors booting your computer, slow performance due to a full storage drive, or missing or corrupted files, replacement of the hard drive should alleviate these issues.
Neye ihtiyacın var
Power off the device before starting.
Remove the rubber strips that hide the screws using the spudger.
Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
Remove the four screws on the hard drive bracket with a Phillips #0 screwdriver.
Pull the hard drive bracket out.
6 farklı kişi bu kılavuzu tamamladı.
