Ana içeriğe geç
HP 15-db0015dx Optical Drive Replacement
Neye ihtiyacın var
  1. HP 15-db0015dx Optical Drive Replacement, Optical Drive: adım 1, 3 resimden 1. HP 15-db0015dx Optical Drive Replacement, Optical Drive: adım 1, 3 resimden 2. HP 15-db0015dx Optical Drive Replacement, Optical Drive: adım 1, 3 resimden 3.
    • Make sure the disc drive is clear of any discs.
    • Remove the rubber stays from the bottom of the device.
    • Using a Phillips #0 screwdriver, remove the eleven screws on the back cover.
  2. HP 15-db0015dx Optical Drive Replacement: adım 2, 3 resimden 1. HP 15-db0015dx Optical Drive Replacement: adım 2, 3 resimden 2. HP 15-db0015dx Optical Drive Replacement: adım 2, 3 resimden 3.
    • Use a spudger to pry open the back cover.
    • The disk drive must be disconnected by pulling it to the left before removing the back panel.
  3. HP 15-db0015dx Optical Drive Replacement: adım 3, 3 resimden 1. HP 15-db0015dx Optical Drive Replacement: adım 3, 3 resimden 2. HP 15-db0015dx Optical Drive Replacement: adım 3, 3 resimden 3.
    • Slide the disk drive to the left and remove.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 1,109
