Ana içeriğe geç
HP 15-db0015dx USB/SD Card Reader Replacement
Neye ihtiyacın var
  1. HP 15-db0015dx USB/SD Card Reader Replacement, Battery: adım 1, 2 resimden 1. HP 15-db0015dx USB/SD Card Reader Replacement, Battery: adım 1, 2 resimden 2.
    • Power off the device before starting.
    • Remove the rubber strips that hide the screws using the spudger.
    • Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
  2. HP 15-db0015dx USB/SD Card Reader Replacement: adım 2, 3 resimden 1. HP 15-db0015dx USB/SD Card Reader Replacement: adım 2, 3 resimden 2. HP 15-db0015dx USB/SD Card Reader Replacement: adım 2, 3 resimden 3.
    • Use the spudger tool to pry open the back cover.
    • Lift the back panel to access the inside.
    • Slide the CD drive to the left, and remove.
  3. HP 15-db0015dx USB/SD Card Reader Replacement: adım 3, 3 resimden 1. HP 15-db0015dx USB/SD Card Reader Replacement: adım 3, 3 resimden 2. HP 15-db0015dx USB/SD Card Reader Replacement: adım 3, 3 resimden 3.
    • Unscrew the three battery screws with a Phillips #0 screwdriver.
    • Lift the battery up, disconnecting the connector first.
    • Push forward and remove the battery.
  4. HP 15-db0015dx USB/SD Card Reader Replacement, Hard Drive: adım 4, 3 resimden 1. HP 15-db0015dx USB/SD Card Reader Replacement, Hard Drive: adım 4, 3 resimden 2. HP 15-db0015dx USB/SD Card Reader Replacement, Hard Drive: adım 4, 3 resimden 3.
    • Remove the four screws on the hard drive bracket with a Phillips #0 screwdriver.
    • Pull the hard drive bracket out.
  5. HP 15-db0015dx USB/SD Card Reader Replacement: adım 5, 1 resimden 1.
    • Remove the hard drive from the connector by sliding it to the left until the connector is disengaged.
  6. HP 15-db0015dx USB/SD Card Reader Replacement, USB/SD Card Reader: adım 6, 3 resimden 1. HP 15-db0015dx USB/SD Card Reader Replacement, USB/SD Card Reader: adım 6, 3 resimden 2. HP 15-db0015dx USB/SD Card Reader Replacement, USB/SD Card Reader: adım 6, 3 resimden 3.
    • Lift up on the connector pin that attaches the SD card reader to the motherboard
    • Gently pull the wire out
  7. HP 15-db0015dx USB/SD Card Reader Replacement: adım 7, 2 resimden 1. HP 15-db0015dx USB/SD Card Reader Replacement: adım 7, 2 resimden 2.
    • Snake the wire underneath the battery support
    • Pull the wire out to allow the SD Card reader to be removed
  8. HP 15-db0015dx USB/SD Card Reader Replacement: adım 8, 3 resimden 1. HP 15-db0015dx USB/SD Card Reader Replacement: adım 8, 3 resimden 2. HP 15-db0015dx USB/SD Card Reader Replacement: adım 8, 3 resimden 3.
    • Remove the two Phillips #0 screws holding the SD Card reader in place.
    • Gently pull the SD card reader up and out of the slot.
    • A spudger may have to be used to pop the SD card reader out of place.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 660
