Ana içeriğe geç
HP 15-db0015dx WLAN Module Replacement
Neye ihtiyacın var
  1. HP 15-db0015dx WLAN Module Replacement, Battery: adım 1, 2 resimden 1. HP 15-db0015dx WLAN Module Replacement, Battery: adım 1, 2 resimden 2.
    • Power off the device before starting.
    • Remove the rubber strips that hide the screws using the spudger.
    • Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
  2. HP 15-db0015dx WLAN Module Replacement: adım 2, 3 resimden 1. HP 15-db0015dx WLAN Module Replacement: adım 2, 3 resimden 2. HP 15-db0015dx WLAN Module Replacement: adım 2, 3 resimden 3.
    • Use the spudger tool to pry open the back cover.
    • Lift the back panel to access the inside.
    • Slide the CD drive to the left, and remove.
  3. HP 15-db0015dx WLAN Module Replacement: adım 3, 3 resimden 1. HP 15-db0015dx WLAN Module Replacement: adım 3, 3 resimden 2. HP 15-db0015dx WLAN Module Replacement: adım 3, 3 resimden 3.
    • Unscrew the three battery screws with a Phillips #0 screwdriver.
    • Lift the battery up, disconnecting the connector first.
    • Push forward and remove the battery.
  4. HP 15-db0015dx WLAN Module Replacement, WLAN Module: adım 4, 1 resimden 1.
    • Disconnect the wire attached to the WLAN card by prying it upward from the card.
  5. HP 15-db0015dx WLAN Module Replacement: adım 5, 1 resimden 1.
    • Remove the screw holding down the card with a Phillips #0 screwdriver.
  6. HP 15-db0015dx WLAN Module Replacement: adım 6, 2 resimden 1. HP 15-db0015dx WLAN Module Replacement: adım 6, 2 resimden 2.
    • Pull the WLAN Module out of the connection port.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 669
