Ana içeriğe geç
HP 15-dw0xxx Battery Replacement
Neye ihtiyacın var
  1. HP 15-dw0xxx Battery Replacement, Battery: adım 1, 2 resimden 1. HP 15-dw0xxx Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the seven screws from the rear panel using a Phillips #00 screwdriver.
  2. HP 15-dw0xxx Battery Replacement: adım 2, 2 resimden 1. HP 15-dw0xxx Battery Replacement: adım 2, 2 resimden 2.
    • Insert the tip of a spudger between the rear panel and the top case to separate the top case from bottom case.
    • Slowly slide the spudger around the device to loosen the bottom part.
    • Pull the bottom case out gently.
  3. HP 15-dw0xxx Battery Replacement: adım 3, 2 resimden 1. HP 15-dw0xxx Battery Replacement: adım 3, 2 resimden 2.
    • Remove the three screws around the battery using a Phillips #00 screwdriver.
  4. HP 15-dw0xxx Battery Replacement: adım 4, 1 resimden 1.
    • Slowly use your two hands to take the current battery out.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Dalha Mohammed
109 İtibar
1 Kılavuz yazıldı
Ekip
York University, Team B-9, Allen Fall 2022 York University, Team B-9, Allen Fall 2022 üyesi
YORK-ALLEN-F22SBG9
2 Üyeler
3 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where can I get a new battery?
Aviv Tenenbaum Haddar - Yanıt
Can I repair my HP's battery to work again. It still looks new, but it's dead.
John - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 43
Son 30 gün: 276
Her zaman: 5,890
