Ana içeriğe geç
HP 15-dy2024nr Fan Assembly Replacement
Neye ihtiyacın var
  1. HP 15-dy2024nr Fan Assembly Replacement, Back Cover: adım 1, 2 resimden 1. HP 15-dy2024nr Fan Assembly Replacement, Back Cover: adım 1, 2 resimden 2.
    • Use a spudger to peel one corner of each of the rubber feet from the bottom of the laptop.
    • Gently peel the feet from the laptop using the spudger revealing the screws underneath.
    • If the rubber foot peels away but leaves adhesive behind you must peel the adhesive away before removing the screws.
  2. HP 15-dy2024nr Fan Assembly Replacement: adım 2, 3 resimden 1. HP 15-dy2024nr Fan Assembly Replacement: adım 2, 3 resimden 2. HP 15-dy2024nr Fan Assembly Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove:
    • Two 2.5mm x 6mm screws
    • Six 2mm x 6mm screws
    • Be sure to keep different screw sizes separated.
  3. HP 15-dy2024nr Fan Assembly Replacement: adım 3, 3 resimden 1. HP 15-dy2024nr Fan Assembly Replacement: adım 3, 3 resimden 2. HP 15-dy2024nr Fan Assembly Replacement: adım 3, 3 resimden 3.
    • Insert an iFixit opening tool into the seam between the keyboard area and bottom cover.
    • Using another iFixit opening tool, slide along the seam to unhook the clips.
    • There are clips all the way around the seam. You may hear a popping sound as the clips come loose. This step may require some force to separate the back cover from the laptop.
    • When the front of the laptop is open, you can use your finger to hold a corner open then slide an iFixit opening tool along the seam toward the back corner.
    • After the clips have been released, flip the laptop over and lift the cover.
  4. HP 15-dy2024nr Fan Assembly Replacement, Battery: adım 4, 3 resimden 1. HP 15-dy2024nr Fan Assembly Replacement, Battery: adım 4, 3 resimden 2. HP 15-dy2024nr Fan Assembly Replacement, Battery: adım 4, 3 resimden 3.
    • Remove five 2.0mm x 3.0mm screws using a Phillips #00 screwdriver.
    • Use the iFixit opening picks to lift the battery away from the laptop.
  5. HP 15-dy2024nr Fan Assembly Replacement: adım 5, 3 resimden 1. HP 15-dy2024nr Fan Assembly Replacement: adım 5, 3 resimden 2. HP 15-dy2024nr Fan Assembly Replacement: adım 5, 3 resimden 3.
    • Be aware that the battery is plugged into the motherboard.
    • Unplug the battery from the motherboard.
    • Lift the battery away from the laptop and remove.
  6. HP 15-dy2024nr Fan Assembly Replacement, Fan Assembly: adım 6, 2 resimden 1. HP 15-dy2024nr Fan Assembly Replacement, Fan Assembly: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • If your fan needs to be cleaned, do that now. If it is not working properly, continue with these steps to remove the broken fan.
    • Use the nylon tipped reverse tweezers to lift the cables up from off the motherboard before attempting to disconnect the connector from the motherboard.
    • Do not use the tweezers to pull the cables off the motherboard.
  7. HP 15-dy2024nr Fan Assembly Replacement: adım 7, 2 resimden 1. HP 15-dy2024nr Fan Assembly Replacement: adım 7, 2 resimden 2.
    • Wedge the Halberd spudger between the black plastic connector and the motherboard.
    • Lightly twist the spudger blade up. The connector should pop off.
  8. HP 15-dy2024nr Fan Assembly Replacement: adım 8, 3 resimden 1. HP 15-dy2024nr Fan Assembly Replacement: adım 8, 3 resimden 2. HP 15-dy2024nr Fan Assembly Replacement: adım 8, 3 resimden 3.
    • Remove the three chrome-plated 2.0mm x 3.0mm screws holding the fan assembly in place using a Phillips #0 screwdriver.
    • Lift the fan assembly out of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nathaniel Reeves
366 İtibar
2 adet Kılavuz yazıldı
Ekip
Utah Tech University, Team 1-4, McMurrin Fall 2022 Utah Tech University, Team 1-4, McMurrin Fall 2022 üyesi
UTAHTECH-MCMURRIN-F22S1G4
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 202
