Ana içeriğe geç
HP 15-dy2024nr SSD Replacement
Neye ihtiyacın var
  1. HP 15-dy2024nr SSD Replacement, Back Cover: adım 1, 2 resimden 1. HP 15-dy2024nr SSD Replacement, Back Cover: adım 1, 2 resimden 2.
    • Use a spudger to peel one corner of each of the rubber feet from the bottom of the laptop.
    • Gently peel the feet from the laptop using the spudger revealing the screws underneath.
    • If the rubber foot peels away but leaves adhesive behind you must peel the adhesive away before removing the screws.
    FixBot'a Sor
  2. HP 15-dy2024nr SSD Replacement: adım 2, 3 resimden 1. HP 15-dy2024nr SSD Replacement: adım 2, 3 resimden 2. HP 15-dy2024nr SSD Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove:
    • Two 2.5mm x 6mm screws
    • Six 2mm x 6mm screws
    • Be sure to keep different screw sizes separated.
    FixBot'a Sor
  3. HP 15-dy2024nr SSD Replacement: adım 3, 3 resimden 1. HP 15-dy2024nr SSD Replacement: adım 3, 3 resimden 2. HP 15-dy2024nr SSD Replacement: adım 3, 3 resimden 3.
    • Insert an iFixit opening tool into the seam between the keyboard area and bottom cover.
    • Using another iFixit opening tool, slide along the seam to unhook the clips.
    • There are clips all the way around the seam. You may hear a popping sound as the clips come loose. This step may require some force to separate the back cover from the laptop.
    • When the front of the laptop is open, you can use your finger to hold a corner open then slide an iFixit opening tool along the seam toward the back corner.
    • After the clips have been released, flip the laptop over and lift the cover.
    FixBot'a Sor
  4. HP 15-dy2024nr SSD Replacement, Battery: adım 4, 3 resimden 1. HP 15-dy2024nr SSD Replacement, Battery: adım 4, 3 resimden 2. HP 15-dy2024nr SSD Replacement, Battery: adım 4, 3 resimden 3.
    • Remove five 2.0mm x 3.0mm screws using a Phillips #00 screwdriver.
    • Use the iFixit opening picks to lift the battery away from the laptop.
    FixBot'a Sor
  5. HP 15-dy2024nr SSD Replacement: adım 5, 3 resimden 1. HP 15-dy2024nr SSD Replacement: adım 5, 3 resimden 2. HP 15-dy2024nr SSD Replacement: adım 5, 3 resimden 3.
    • Be aware that the battery is plugged into the motherboard.
    • Unplug the battery from the motherboard.
    • Lift the battery away from the laptop and remove.
    FixBot'a Sor
  6. HP 15-dy2024nr SSD Replacement, SSD: adım 6, 2 resimden 1. HP 15-dy2024nr SSD Replacement, SSD: adım 6, 2 resimden 2.
    • Remove the single 2 mm screw from the hard drive using a Phillips #00 screwdriver.
    FixBot'a Sor
  7. HP 15-dy2024nr SSD Replacement: adım 7, 2 resimden 1. HP 15-dy2024nr SSD Replacement: adım 7, 2 resimden 2.
    • Pull the SSD away from the connector, while gently lifting it out using your hands.
    FixBot'a Sor
Sonuç
Bir başkası bu kılavuzu tamamladı.
Konnor Young
580 İtibar
4 adet Kılavuz yazıldı
Ekip
Utah Tech University, Team 1-4, McMurrin Fall 2022 Utah Tech University, Team 1-4, McMurrin Fall 2022 üyesi
UTAHTECH-MCMURRIN-F22S1G4
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 53
Her zaman: 1,331
