Ana içeriğe geç
HP 15-dy2702dx Fan Replacement
Neye ihtiyacın var
    1. HP 15-dy2702dx Fan Replacement, Lower Case: adım 1, 1 resimden 1.
      • Remove both of the rubber strips to uncover the hidden screws.
      • You can use a prying tool to help lift an end.
      FixBot'a Sor
      Yorum Ekle
    2. HP 15-dy2702dx Fan Replacement: adım 2, 1 resimden 1.
      • Unscrew all 8 Phillips #1 screws on the bottom panel:
      • Two M2.5x6
      • Six M2x6
      FixBot'a Sor
      Yorum Ekle
    3. HP 15-dy2702dx Fan Replacement: adım 3, 2 resimden 1. HP 15-dy2702dx Fan Replacement: adım 3, 2 resimden 2.
      • Flip the laptop over and open the lid.
      • Separate the bottom panel from the main body by using the iFixit opening tool.
      • Ensure that the bottom panel is completely separated along the edges.
      FixBot'a Sor
      Yorum Ekle
    4. HP 15-dy2702dx Fan Replacement: adım 4, 2 resimden 1. HP 15-dy2702dx Fan Replacement: adım 4, 2 resimden 2.
      • If you can lift the laptop like shown in the first picture, the bottom panel is nearly separated.
      • Close the laptop to allow the back edges to fully separate
      FixBot'a Sor
      Yorum Ekle
    5. HP 15-dy2702dx Fan Replacement: adım 5, 3 resimden 1. HP 15-dy2702dx Fan Replacement: adım 5, 3 resimden 2. HP 15-dy2702dx Fan Replacement: adım 5, 3 resimden 3.
      • Flip the laptop over and carefully remove the lower case.
      FixBot'a Sor
      Yorum Ekle
    1. HP 15-dy2702dx Fan Replacement, Fan: adım 6, 3 resimden 1. HP 15-dy2702dx Fan Replacement, Fan: adım 6, 3 resimden 2. HP 15-dy2702dx Fan Replacement, Fan: adım 6, 3 resimden 3.
      • Use a Phillips #1 screwdriver to unscrew the three screws that secure the fan.
      • These screws sizes are M2x6.
      FixBot'a Sor
      Yorum Ekle
    2. HP 15-dy2702dx Fan Replacement: adım 7, 1 resimden 1.
      • Grip the cord that connects the fan to the motherboard and gently pull out to disconnect the cable from the connector.
      • Alternatively, we recommend using a tool to push the connector out of its socket to avoid damaging the wires.
      FixBot'a Sor
      Yorum Ekle
    3. HP 15-dy2702dx Fan Replacement: adım 8, 2 resimden 1. HP 15-dy2702dx Fan Replacement: adım 8, 2 resimden 2.
      • Gently lift the fan to remove it from the case.
      FixBot'a Sor
      Yorum Ekle
Sonuç
September Oo
418 İtibar
4 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-4, Pee Fall 2023 Gateway, Team 1-4, Pee Fall 2023 üyesi
GCC-PEE-F23S1G4
4 Üyeler
80 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 26
Her zaman: 783
