Ana içeriğe geç
HP 15-dy2702dx Fan Replacement
Neye ihtiyacın var
  1. HP 15-dy2702dx Fan Replacement, Lower Case: adım 1, 1 resimden 1.
    • Remove both of the rubber strips to uncover the hidden screws.
    • You can use a prying tool to help lift an end.
  2. HP 15-dy2702dx Fan Replacement: adım 2, 1 resimden 1.
    • Unscrew all 8 Phillips #0 screws on the bottom panel:
    • Two M2.5x6
    • Six M2x6
  3. HP 15-dy2702dx Fan Replacement: adım 3, 2 resimden 1. HP 15-dy2702dx Fan Replacement: adım 3, 2 resimden 2.
    • Flip the laptop over and open the lid.
    • Separate the bottom panel from the main body by using the iFixit opening tool.
    • Ensure that the bottom panel is completely separated along the edges.
  4. HP 15-dy2702dx Fan Replacement: adım 4, 2 resimden 1. HP 15-dy2702dx Fan Replacement: adım 4, 2 resimden 2.
    • If you can lift the laptop like shown in the first picture, the bottom panel is nearly separated.
    • Close the laptop to allow the back edges to fully separate
  5. HP 15-dy2702dx Fan Replacement: adım 5, 3 resimden 1. HP 15-dy2702dx Fan Replacement: adım 5, 3 resimden 2. HP 15-dy2702dx Fan Replacement: adım 5, 3 resimden 3.
    • Flip the laptop over and carefully remove the lower case.
  6. HP 15-dy2702dx Fan Replacement, Fan: adım 6, 3 resimden 1. HP 15-dy2702dx Fan Replacement, Fan: adım 6, 3 resimden 2. HP 15-dy2702dx Fan Replacement, Fan: adım 6, 3 resimden 3.
    • Use a Phillips #0 screwdriver to unscrew the three screws that secure the fan.
    • These screws sizes are M2x6.
  7. HP 15-dy2702dx Fan Replacement: adım 7, 1 resimden 1.
    • Grip the cord that connects the fan to the motherboard and gently pull out to disconnect the cable from the connector.
    • Alternatively, we recommend using a tool to push the connector out of its socket to avoid damaging the wires.
  8. HP 15-dy2702dx Fan Replacement: adım 8, 2 resimden 1. HP 15-dy2702dx Fan Replacement: adım 8, 2 resimden 2.
    • Gently lift the fan to remove it from the case.
Sonuç
September Oo
397 İtibar
4 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-4, Pee Fall 2023 Gateway, Team 1-4, Pee Fall 2023 üyesi
GCC-PEE-F23S1G4
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 127
