Ana içeriğe geç
HP 15-dy2702dx SSD Replacement
Neye ihtiyacın var
    1. HP 15-dy2702dx SSD Replacement, Lower Case: adım 1, 1 resimden 1.
      • Remove both of the rubber strips to uncover the hidden screws.
      • You can use a prying tool to help lift an end.
      FixBot'a Sor
      Yorum Ekle
    2. HP 15-dy2702dx SSD Replacement: adım 2, 1 resimden 1.
      • Unscrew all 8 Phillips #1 screws on the bottom panel:
      • Two M2.5x6
      • Six M2x6
      FixBot'a Sor
      Yorum Ekle
    3. HP 15-dy2702dx SSD Replacement: adım 3, 2 resimden 1. HP 15-dy2702dx SSD Replacement: adım 3, 2 resimden 2.
      • Flip the laptop over and open the lid.
      • Separate the bottom panel from the main body by using the iFixit opening tool.
      • Ensure that the bottom panel is completely separated along the edges.
      FixBot'a Sor
      Yorum Ekle
    4. HP 15-dy2702dx SSD Replacement: adım 4, 2 resimden 1. HP 15-dy2702dx SSD Replacement: adım 4, 2 resimden 2.
      • If you can lift the laptop like shown in the first picture, the bottom panel is nearly separated.
      • Close the laptop to allow the back edges to fully separate
      FixBot'a Sor
      Yorum Ekle
    5. HP 15-dy2702dx SSD Replacement: adım 5, 3 resimden 1. HP 15-dy2702dx SSD Replacement: adım 5, 3 resimden 2. HP 15-dy2702dx SSD Replacement: adım 5, 3 resimden 3.
      • Flip the laptop over and carefully remove the lower case.
      FixBot'a Sor
      Yorum Ekle
    1. HP 15-dy2702dx SSD Replacement, SSD: adım 6, 3 resimden 1. HP 15-dy2702dx SSD Replacement, SSD: adım 6, 3 resimden 2. HP 15-dy2702dx SSD Replacement, SSD: adım 6, 3 resimden 3.
      • Locate the storage drive.
      • Unscrew the single screw holding the drive in place.
      • The screw is a M2x3 mm Phillips #1 head screw.
      FixBot'a Sor
      Yorum Ekle
    2. HP 15-dy2702dx SSD Replacement: adım 7, 3 resimden 1. HP 15-dy2702dx SSD Replacement: adım 7, 3 resimden 2. HP 15-dy2702dx SSD Replacement: adım 7, 3 resimden 3.
      • Grab the drive by its side and gently pull it out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Zander Herbold
700 İtibar
4 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-4, Pee Fall 2023 Gateway, Team 1-4, Pee Fall 2023 üyesi
GCC-PEE-F23S1G4
4 Üyeler
80 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 31
Son 30 gün: 117
Her zaman: 1,379
