Ana içeriğe geç
HP 15-ef2025nr Fan Replacement
Neye ihtiyacın var
  1. HP 15-ef2025nr Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop upside down with the hinge facing you.
  2. HP 15-ef2025nr Fan Replacement: adım 2, 2 resimden 1. HP 15-ef2025nr Fan Replacement: adım 2, 2 resimden 2.
    • Use an opening tool to remove the rubber strips by prying up a corner and gently pulling off the strip.
  3. HP 15-ef2025nr Fan Replacement: adım 3, 2 resimden 1. HP 15-ef2025nr Fan Replacement: adım 3, 2 resimden 2.
    • Use a Phillips screwdriver to remove the eight 3 mm screws (including the 2 screws that were not under the rubber strips) securing the lower case.
  4. HP 15-ef2025nr Fan Replacement: adım 4, 2 resimden 1. HP 15-ef2025nr Fan Replacement: adım 4, 2 resimden 2.
    • Flip the laptop over and open the lid.
    • Insert an opening tool into the seam between the edge of the lower case and the chassis.
    • Gently pry around the entire perimeter until the lower case separates from the chassis.
    • Close the lid and flip the laptop back over.
    • Remove the lower case.
  5. HP 15-ef2025nr Fan Replacement: adım 5, 3 resimden 1. HP 15-ef2025nr Fan Replacement: adım 5, 3 resimden 2. HP 15-ef2025nr Fan Replacement: adım 5, 3 resimden 3.
    • Remove the five 2 mm Phillips screws holding the battery down.
    • Take care not to puncture, bend, or twist the battery. Lithium batteries can be very volatile. Follow all proper hazardous disposal laws where you live.
    • Gently lift the front edge of the battery up to disconnect the socket.
    • Lift the battery up and out.
  6. HP 15-ef2025nr Fan Replacement, Fan: adım 6, 3 resimden 1. HP 15-ef2025nr Fan Replacement, Fan: adım 6, 3 resimden 2. HP 15-ef2025nr Fan Replacement, Fan: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to pull the fan connector directly out of its motherboard socket.
    • Do not pull on the wires; they are very delicate.
  7. HP 15-ef2025nr Fan Replacement: adım 7, 3 resimden 1. HP 15-ef2025nr Fan Replacement: adım 7, 3 resimden 2. HP 15-ef2025nr Fan Replacement: adım 7, 3 resimden 3.
    • Remove the three 2 mm Phillips screws at the top corners and four o'clock position on the fan.
    • Remove the fan.
Sonuç
kyle mccomas
291 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 176
