Ana içeriğe geç
HP 15-f009wm Cooling System Replacement
Neye ihtiyacın var
  1. HP 15-f009wm Cooling System Replacement, Battery: adım 1, 2 resimden 1. HP 15-f009wm Cooling System Replacement, Battery: adım 1, 2 resimden 2.
    • Turn laptop upside down.
    • Flip the lock switch to the unlocked setting.
  2. HP 15-f009wm Cooling System Replacement: adım 2, 3 resimden 1. HP 15-f009wm Cooling System Replacement: adım 2, 3 resimden 2. HP 15-f009wm Cooling System Replacement: adım 2, 3 resimden 3.
    • Flip the release switch.
    • Once the flip is switched, the battery should pop out.
  3. HP 15-f009wm Cooling System Replacement: adım 3, 2 resimden 1. HP 15-f009wm Cooling System Replacement: adım 3, 2 resimden 2.
    • Slide the battery out.
  4. HP 15-f009wm Cooling System Replacement, RAM: adım 4, 3 resimden 1. HP 15-f009wm Cooling System Replacement, RAM: adım 4, 3 resimden 2. HP 15-f009wm Cooling System Replacement, RAM: adım 4, 3 resimden 3.
    • Remove the two Phillips #1 screws from the RAM panel.
  5. HP 15-f009wm Cooling System Replacement: adım 5, 3 resimden 1. HP 15-f009wm Cooling System Replacement: adım 5, 3 resimden 2. HP 15-f009wm Cooling System Replacement: adım 5, 3 resimden 3.
    • Use the plastic opening tool to pop the panel off.
  6. HP 15-f009wm Cooling System Replacement: adım 6, 3 resimden 1. HP 15-f009wm Cooling System Replacement: adım 6, 3 resimden 2. HP 15-f009wm Cooling System Replacement: adım 6, 3 resimden 3.
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  7. HP 15-f009wm Cooling System Replacement: adım 7, 1 resimden 1.
    • Remove the RAM chip from the laptop.
  8. HP 15-f009wm Cooling System Replacement, Hard Drive: adım 8, 1 resimden 1.
    • Remove the sixteen 7mm Phillips #1 screws from the bottom panel.
  9. HP 15-f009wm Cooling System Replacement: adım 9, 3 resimden 1. HP 15-f009wm Cooling System Replacement: adım 9, 3 resimden 2. HP 15-f009wm Cooling System Replacement: adım 9, 3 resimden 3.
    • Pull the disk drive out of the laptop.
  10. HP 15-f009wm Cooling System Replacement: adım 10, 1 resimden 1.
    • Remove the three 2mm Phillips #00 screws found underneath the disk drive.
  11. HP 15-f009wm Cooling System Replacement: adım 11, 3 resimden 1. HP 15-f009wm Cooling System Replacement: adım 11, 3 resimden 2. HP 15-f009wm Cooling System Replacement: adım 11, 3 resimden 3.
    • Remove the single 4mm Phillips #1 screw from the Wi-Fi card.
    • Pull the Wi-Fi card out of the motherboard.
  12. HP 15-f009wm Cooling System Replacement: adım 12, 3 resimden 1. HP 15-f009wm Cooling System Replacement: adım 12, 3 resimden 2. HP 15-f009wm Cooling System Replacement: adım 12, 3 resimden 3.
    • Open the laptop.
    • Use a plastic opening tool to pop out the keyboard by starting at the top and working your way around the perimeter.
  13. HP 15-f009wm Cooling System Replacement: adım 13, 2 resimden 1. HP 15-f009wm Cooling System Replacement: adım 13, 2 resimden 2.
    • Open the screen up until it lays flat and rotate the laptop until the screen is closest to you.
    • Lift the keyboard from the laptop.
    • Use a spudger to lift up the black latch on the ZIF connector and remove the ribbon cable.
  14. HP 15-f009wm Cooling System Replacement: adım 14, 1 resimden 1.
    • Remove the five 7mm Phillips #1 screws found underneath the keyboard.
  15. HP 15-f009wm Cooling System Replacement: adım 15, 3 resimden 1. HP 15-f009wm Cooling System Replacement: adım 15, 3 resimden 2. HP 15-f009wm Cooling System Replacement: adım 15, 3 resimden 3.
    • Use a spudger to lift the black tabs on the ZIF connectors.
    • Remove the ribbon cables from the ZIF connectors.
  16. HP 15-f009wm Cooling System Replacement: adım 16, 3 resimden 1. HP 15-f009wm Cooling System Replacement: adım 16, 3 resimden 2. HP 15-f009wm Cooling System Replacement: adım 16, 3 resimden 3.
    • Use a plastic opening tool to pop the palm rest off of the laptop.
    • Lift and remove the palm rest.
  17. HP 15-f009wm Cooling System Replacement: adım 17, 3 resimden 1. HP 15-f009wm Cooling System Replacement: adım 17, 3 resimden 2. HP 15-f009wm Cooling System Replacement: adım 17, 3 resimden 3.
    • Use a spudger to lift up the black latch on the ZIF connector.
    • Remove the USB/AUX port ribbon cable from the ZIF connector on the motherboard.
  18. HP 15-f009wm Cooling System Replacement: adım 18, 2 resimden 1. HP 15-f009wm Cooling System Replacement: adım 18, 2 resimden 2.
    • Remove the single 7mm Phillips #1 screw from the USB/AUX board.
    • Remove the USB/AUX board from the laptop.
  19. HP 15-f009wm Cooling System Replacement: adım 19, 3 resimden 1. HP 15-f009wm Cooling System Replacement: adım 19, 3 resimden 2. HP 15-f009wm Cooling System Replacement: adım 19, 3 resimden 3.
    • Lift the Hard Drive from the laptop.
    • Disconnect the hard drive from the motherboard.
  20. HP 15-f009wm Cooling System Replacement, Motherboard: adım 20, 2 resimden 1. HP 15-f009wm Cooling System Replacement, Motherboard: adım 20, 2 resimden 2.
    • Remove the four 4mm Phillips #1 screws from the motherboard.
    • Lift the motherboard up from the computer.
    • There will be three wires connected underneath.
  21. HP 15-f009wm Cooling System Replacement: adım 21, 3 resimden 1. HP 15-f009wm Cooling System Replacement: adım 21, 3 resimden 2. HP 15-f009wm Cooling System Replacement: adım 21, 3 resimden 3.
    • Disconnect the speaker.
  22. HP 15-f009wm Cooling System Replacement: adım 22, 3 resimden 1. HP 15-f009wm Cooling System Replacement: adım 22, 3 resimden 2. HP 15-f009wm Cooling System Replacement: adım 22, 3 resimden 3.
    • Remove the display connection wire. Lift the connection straight up from the motherboard.
  23. HP 15-f009wm Cooling System Replacement: adım 23, 3 resimden 1. HP 15-f009wm Cooling System Replacement: adım 23, 3 resimden 2. HP 15-f009wm Cooling System Replacement: adım 23, 3 resimden 3.
    • Flip the motherboard over.
    • Disconnect the charging port wire from the motherboard.
  24. HP 15-f009wm Cooling System Replacement, Cooling System: adım 24, 3 resimden 1. HP 15-f009wm Cooling System Replacement, Cooling System: adım 24, 3 resimden 2. HP 15-f009wm Cooling System Replacement, Cooling System: adım 24, 3 resimden 3.
    • Use the PH1 Screwdriver to remove the two screws (7 mm) which hold the fan in place.
  25. HP 15-f009wm Cooling System Replacement: adım 25, 3 resimden 1. HP 15-f009wm Cooling System Replacement: adım 25, 3 resimden 2. HP 15-f009wm Cooling System Replacement: adım 25, 3 resimden 3.
    • The fan will now only be connected via its connection wire.
    • Unplug the connection wire.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alex Birchler
1.008 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G2, Nance Spring 2018 USF Tampa, Team S2-G2, Nance Spring 2018 üyesi
USFT-NANCE-S18S2G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 430
