Giriş
This guide explains how to remove the Cooling System from the HP 15-f009wm notebook computer. This could be done to replace a malfunctioning Cooling System.
Neye ihtiyacın var
Remove the four 4mm Phillips #1 screws from the motherboard.
Lift the motherboard up from the computer.
Use the PH1 Screwdriver to remove the two screws (7 mm) which hold the fan in place.
Bir başkası bu kılavuzu tamamladı.
