Giriş
In the case that the screen on your laptop doesn’t show anything or the touch display is unresponsive, your laptop may have a faulty screen.
Neye ihtiyacın var
Turn power off using the power button located in the top left corner of the keyboard. Press and hold the power button for 3 seconds until it turns off.
After removing the battery, remove the bezel. Do this by prying it away from the faulty screen using the spudger.
Make sure screen is angles as far back as possible to fully remove the bottom hinges of the bezel without damaging the laptop.
4 farklı kişi bu kılavuzu tamamladı.
