Ana içeriğe geç
HP 15-f162dx RAM Replacement
Neye ihtiyacın var
  1. HP 15-f162dx RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Be sure to power off and unplug your device before you begin the repair.
  2. HP 15-f162dx RAM Replacement: adım 2, 1 resimden 1.
    • Use a small Phillips screwdriver to remove the four screws from the RAM cover. Remove the RAM cover.
    • Remove it at an angle and not straight up so you don't damage the socket.
  3. HP 15-f162dx RAM Replacement: adım 3, 1 resimden 1.
    • Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it.
    • The RAM will pop up by a few millimeters.
    • Repeat steps in reverse order to reassemble the computer with new RAM
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 387
