Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Parçalar
Hiçbir parça belirtilmedi.
  1. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Use phillips screwdriver flathead 2.5 mm to open the cover.
    • Use phillips screwdriver flathead 2.5 mm to open the cover.
  2. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Use the Metal spudger set to gently open the front cover
    • Use the Metal spudger set to gently open the front cover
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Use phillips screwdriver JIS J00 to open the screws holding the motherboard.
    • Use phillips screwdriver JIS J00 to open the screws holding the motherboard.
  5. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Pull out the wires connected to the motherboard, so that it is removable. Then, take off the motherboard. Pull out the wires connected to the motherboard, so that it is removable. Then, take off the motherboard. Pull out the wires connected to the motherboard, so that it is removable. Then, take off the motherboard.
    • Pull out the wires connected to the motherboard, so that it is removable. Then, take off the motherboard.
  6. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Use the spudger set to gently take out the RAM and then replace it. Make sure to replace the RAM from the other side, underneeth the labtop.
    • Use the spudger set to gently take out the RAM and then replace it.
    • Make sure to replace the RAM from the other side, underneeth the labtop.
Bitiş Çizgisi
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 141
