Ana içeriğe geç
HP 15-g010dx Button Board Replacement
Neye ihtiyacın var
  1. HP 15-g010dx Button Board Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the latch towards the center of the laptop so the unlock emblem appears.
    FixBot'a Sor
    Yorum Ekle
  2. HP 15-g010dx Button Board Replacement: adım 2, 1 resimden 1.
    • Place your finger on the left latch and slide it towards the center of the laptop.
    FixBot'a Sor
    Yorum Ekle
  3. HP 15-g010dx Button Board Replacement: adım 3, 1 resimden 1.
    • Pull on the battery to remove.
    FixBot'a Sor
    Yorum Ekle
  4. HP 15-g010dx Button Board Replacement, Keyboard: adım 4, 1 resimden 1.
    • Remove the two 5 mm screws with the Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. HP 15-g010dx Button Board Replacement: adım 5, 1 resimden 1.
    • Using either a credit card or flat spudger, wedge it between the palm rest and the keyboard.
    FixBot'a Sor
    Yorum Ekle
  6. HP 15-g010dx Button Board Replacement: adım 6, 1 resimden 1.
    • Using the tool of your choice, gently pry up on the top of the keyboard.
    FixBot'a Sor
    Yorum Ekle
  7. HP 15-g010dx Button Board Replacement: adım 7, 1 resimden 1.
    • Release the top of the keyboard.
    FixBot'a Sor
    Yorum Ekle
  8. HP 15-g010dx Button Board Replacement: adım 8, 1 resimden 1.
    • Remove the ZIF connector that connects the laptop to the keyboard cable.
    FixBot'a Sor
    Yorum Ekle
  9. HP 15-g010dx Button Board Replacement, Button Board: adım 9, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove all the 5 millimeter screws located on the bottom of the laptop.
    FixBot'a Sor
    Yorum Ekle
  10. HP 15-g010dx Button Board Replacement: adım 10, 1 resimden 1.
    • Using the spudger, remove the two rubber feet that are located near the battery.
    FixBot'a Sor
    Yorum Ekle
  11. HP 15-g010dx Button Board Replacement: adım 11, 1 resimden 1.
    • Now remove the two Phillips screws that are located below the rubber feet.
    FixBot'a Sor
    Yorum Ekle
  12. HP 15-g010dx Button Board Replacement: adım 12, 3 resimden 1. HP 15-g010dx Button Board Replacement: adım 12, 3 resimden 2. HP 15-g010dx Button Board Replacement: adım 12, 3 resimden 3.
    • Remove the optical drive by pulling it out by hand.
    FixBot'a Sor
    Yorum Ekle
  13. HP 15-g010dx Button Board Replacement: adım 13, 1 resimden 1.
    • Remove the two Phillips screws inside the optical drive housing.
    FixBot'a Sor
    Yorum Ekle
  14. HP 15-g010dx Button Board Replacement: adım 14, 1 resimden 1.
    • Disconnect the power button ribbon cable by lifting the connector.
    FixBot'a Sor
    Yorum Ekle
  15. HP 15-g010dx Button Board Replacement: adım 15, 1 resimden 1.
    • Now disconnect the touch pad ribbon cable by lifting the connector.
    FixBot'a Sor
    Yorum Ekle
  16. HP 15-g010dx Button Board Replacement: adım 16, 3 resimden 1. HP 15-g010dx Button Board Replacement: adım 16, 3 resimden 2. HP 15-g010dx Button Board Replacement: adım 16, 3 resimden 3.
    • Remove the screws indicated by an arrow stamped into the metal.
    FixBot'a Sor
    Yorum Ekle
  17. HP 15-g010dx Button Board Replacement: adım 17, 1 resimden 1.
    • Insert the spudger between the palmrest and the laptop body.
    FixBot'a Sor
    Yorum Ekle
  18. HP 15-g010dx Button Board Replacement: adım 18, 1 resimden 1.
    • Lift up on palm rest, while working the spudger around the perimeter.
    FixBot'a Sor
    Yorum Ekle
  19. HP 15-g010dx Button Board Replacement: adım 19, 2 resimden 1. HP 15-g010dx Button Board Replacement: adım 19, 2 resimden 2.
    • Remove palm rest and flip it over.
    FixBot'a Sor
    Yorum Ekle
  20. HP 15-g010dx Button Board Replacement: adım 20, 2 resimden 1. HP 15-g010dx Button Board Replacement: adım 20, 2 resimden 2.
    • Release the cable connected to the button board.
    FixBot'a Sor
    Yorum Ekle
  21. HP 15-g010dx Button Board Replacement: adım 21, 2 resimden 1. HP 15-g010dx Button Board Replacement: adım 21, 2 resimden 2.
    • Remove the two Phillips screws securing the button board.
    FixBot'a Sor
    Yorum Ekle
  22. HP 15-g010dx Button Board Replacement: adım 22, 1 resimden 1.
    • Remove button board.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 692
