Ana içeriğe geç
HP 15-g010dx Speakers Replacement
Neye ihtiyacın var
  1. HP 15-g010dx Speakers Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the latch towards the center of the laptop so the unlock emblem appears.
  2. HP 15-g010dx Speakers Replacement: adım 2, 1 resimden 1.
    • Place your finger on the left latch and slide it towards the center of the laptop.
  3. HP 15-g010dx Speakers Replacement: adım 3, 1 resimden 1.
    • Pull on the battery to remove.
  4. HP 15-g010dx Speakers Replacement, Keyboard: adım 4, 1 resimden 1.
    • Remove the two 5 mm screws with the Phillips #00 screwdriver.
  5. HP 15-g010dx Speakers Replacement: adım 5, 1 resimden 1.
    • Using either a credit card or flat spudger, wedge it between the palm rest and the keyboard.
  6. HP 15-g010dx Speakers Replacement: adım 6, 1 resimden 1.
    • Using the tool of your choice, gently pry up on the top of the keyboard.
  7. HP 15-g010dx Speakers Replacement: adım 7, 1 resimden 1.
    • Release the top of the keyboard.
  8. HP 15-g010dx Speakers Replacement: adım 8, 1 resimden 1.
    • Remove the ZIF connector that connects the laptop to the keyboard cable.
  9. HP 15-g010dx Speakers Replacement, Speakers: adım 9, 1 resimden 1.
    • Using the Phillips #00 screwdriver, remove the 5 millimeter screws that are visible.
  10. HP 15-g010dx Speakers Replacement: adım 10, 2 resimden 1. HP 15-g010dx Speakers Replacement: adım 10, 2 resimden 2.
    • Using the spudger, remove the two rubber feet that are located near the battery.
  11. HP 15-g010dx Speakers Replacement: adım 11, 2 resimden 1. HP 15-g010dx Speakers Replacement: adım 11, 2 resimden 2.
    • Now remove the two Phillips screws that are located below the rubber feet.
  12. HP 15-g010dx Speakers Replacement: adım 12, 3 resimden 1. HP 15-g010dx Speakers Replacement: adım 12, 3 resimden 2. HP 15-g010dx Speakers Replacement: adım 12, 3 resimden 3.
    • Remove the optical drive by pulling it out by hand.
  13. HP 15-g010dx Speakers Replacement: adım 13, 1 resimden 1.
    • Remove the two Phillips screws inside the optical drive housing.
  14. HP 15-g010dx Speakers Replacement: adım 14, 1 resimden 1.
    • Disconnect the power button ribbon cable by lifting the connector.
  15. HP 15-g010dx Speakers Replacement: adım 15, 3 resimden 1. HP 15-g010dx Speakers Replacement: adım 15, 3 resimden 2. HP 15-g010dx Speakers Replacement: adım 15, 3 resimden 3.
    • Disconnect the touch pad ribbon cable by lifting up on the connector.
  16. HP 15-g010dx Speakers Replacement: adım 16, 3 resimden 1. HP 15-g010dx Speakers Replacement: adım 16, 3 resimden 2. HP 15-g010dx Speakers Replacement: adım 16, 3 resimden 3.
    • Now remove the screws indicated by an arrow stamped into the metal, located where the keyboard was.
  17. HP 15-g010dx Speakers Replacement: adım 17, 1 resimden 1.
    • Take the metal spudger and gently insert in between the palm rest and the body.
  18. HP 15-g010dx Speakers Replacement: adım 18, 1 resimden 1.
    • Work the spudger in small increments around the palm rest while lifting it up in the air.
  19. HP 15-g010dx Speakers Replacement: adım 19, 3 resimden 1. HP 15-g010dx Speakers Replacement: adım 19, 3 resimden 2. HP 15-g010dx Speakers Replacement: adım 19, 3 resimden 3.
    • Carefully remove the palm rest and flip it over.
  20. HP 15-g010dx Speakers Replacement: adım 20, 2 resimden 1. HP 15-g010dx Speakers Replacement: adım 20, 2 resimden 2.
    • Lift up on the speaker connectors to unplug the speaker cables.
  21. HP 15-g010dx Speakers Replacement: adım 21, 2 resimden 1. HP 15-g010dx Speakers Replacement: adım 21, 2 resimden 2.
    • Remove the screws that are securing the speakers.
  22. HP 15-g010dx Speakers Replacement: adım 22, 2 resimden 1. HP 15-g010dx Speakers Replacement: adım 22, 2 resimden 2.
    • Remove the speakers.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 9
Her zaman: 347
