Giriş
Use this guide to replace the Hard Disk Drive (HDD) in a ******HP 15-g029wm.
Neye ihtiyacın var
Unplug any charging cord or accessories connected to the device before beginning.
Remove the following Phillips screws on the lower case:
Nine 5 mm
One 6 mm
Flip the device face up and open the lid.
Insert an opening pick under the keyboard and pry around the perimeter of the keyboard until it fully releases.
Lift the keyboard slightly.
Use your fingers or an opening pick to unlock the ZIF locking flap that secures the keyboard ribbon cable.
Disconnect the keyboard ribbon cable.
Lift the keyboard off.
Remove the two 5 mm Phillips screws that secure the HDD.
Pull the HDD slightly to the right to disconnect it, then lift it up and out of the chassis.
