Giriş
A motherboard can fail for a variety of reasons but this guide assumes that you have diagnosed a system failure and have acquired a new motherboard to use as a replacement. Understanding how a motherboard works is different from knowing how to replace one and only a limited knowledge of computer components is required to complete this process. Follow this guide if you need to replace the motherboard of your HP 15-g071nr.
Neye ihtiyacın var
Using your Phillips #0 screwdriver, remove all of the screws on the back case.
Use one of the plastic opening tools or spudger to lift the keyboard from its housing.
Slowly lift the keyboard at angle toward the left.
Just above the blue plastic connection to the motherboard is a clamp . Use your finger to lift this bar and release the cable.
