Ana içeriğe geç
HP 15-r137wm TouchSmart Cooling Fan Replacement
Neye ihtiyacın var
  1. HP 15-r137wm TouchSmart Cooling Fan Replacement, Front Panel Assembly: adım 1, 3 resimden 1. HP 15-r137wm TouchSmart Cooling Fan Replacement, Front Panel Assembly: adım 1, 3 resimden 2. HP 15-r137wm TouchSmart Cooling Fan Replacement, Front Panel Assembly: adım 1, 3 resimden 3.
    • Make sure that the device is powered off and unplugged before removing components.
    • Remove all ten (10) 5.5 mm Phillips #0 screws.
    • Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
  2. HP 15-r137wm TouchSmart Cooling Fan Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    Satın Al
    • Use a wide plastic opening tool to pry off the top casing.
    • Be cautious not to crack the casing near the keyboard as it is quite fragile.
    • Lift the cover off carefully as there are wires still attached to internal components.
    • After panel is removed, use an anti-static wrist strap to ensure the motherboard does not get any external shocks from static discharge.
  3. HP 15-r137wm TouchSmart Cooling Fan Replacement: adım 3, 1 resimden 1.
    • The connection for the track pad is still connected.
    • Move the keyboard slightly out of the way to locate the connection.
    • Disconnect the small wire protruding from the motherboard underneath the metal plate.
  4. HP 15-r137wm TouchSmart Cooling Fan Replacement: adım 4, 2 resimden 1. HP 15-r137wm TouchSmart Cooling Fan Replacement: adım 4, 2 resimden 2.
    • Locate the connection between the power button and the connecting cable.
    • Do not lift the front panel off to far as the cable is still attached.
    • Remove the cable from the motherboard carefully.
  5. HP 15-r137wm TouchSmart Cooling Fan Replacement, Keyboard: adım 5, 2 resimden 1. HP 15-r137wm TouchSmart Cooling Fan Replacement, Keyboard: adım 5, 2 resimden 2.
    • Disconnect the connection between the keyboard the the motherboard.
  6. HP 15-r137wm TouchSmart Cooling Fan Replacement: adım 6, 2 resimden 1. HP 15-r137wm TouchSmart Cooling Fan Replacement: adım 6, 2 resimden 2.
    • Remove the four (4) 2.5mm by 3.5mm Phillips #0 screws from the metal retaining plate.
    • Lift the metal retaining plate off and away from the device.
  7. HP 15-r137wm TouchSmart Cooling Fan Replacement, Cooling Fan: adım 7, 2 resimden 1. HP 15-r137wm TouchSmart Cooling Fan Replacement, Cooling Fan: adım 7, 2 resimden 2.
    • Locate the small connection on the motherboard and disconnect it by slowly pulling it away from the motherboard.
    • Slowly disconnect the cable as the wires are very small and fragile
  8. HP 15-r137wm TouchSmart Cooling Fan Replacement: adım 8, 2 resimden 1. HP 15-r137wm TouchSmart Cooling Fan Replacement: adım 8, 2 resimden 2.
    • Remove the three (3) 2.5mm by 3.5mm Phillips #0 screws from the fan.
  9. HP 15-r137wm TouchSmart Cooling Fan Replacement: adım 9, 1 resimden 1.
    • Remove the cooling fan from the housing carefully.
    • The fan may be connected to the small foam screen. Pull gently to release it.
Sonuç
Ross B Jacques
881 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G4, Julie Fall 2017 UMass Dartmouth, Team S4-G4, Julie Fall 2017 üyesi
UMASSD-JULIE-F17S4G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 393
