Giriş
You can use this guide to help you safely and effectively remove the keyboard from your HP 15-r137wm TouchSmart device. Be sure to follow all steps in order to ensure proper removal of components and connections. This guide is a prerequisite for all guides of this device following the removal of the keyboard, since it is required to remove the housing to access the components. The prerequisite guide of the front panel assembly is required for this guide.
Neye ihtiyacın var
Remove all ten (10) 5.5 mm Phillips #0 screws.
Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
3 farklı kişi bu kılavuzu tamamladı.
