Ana içeriğe geç
HP 17-bs049dx Back Panel Replacement
Neye ihtiyacın var
  1. HP 17-bs049dx Back Panel Replacement, Battery: adım 1, 1 resimden 1.
    • To remove the battery, simply push the tabs towards each other.
    • The battery will come out with force, be sure to keep anything fragile away from the laptop during this process.
  2. HP 17-bs049dx Back Panel Replacement, Back Panel: adım 2, 1 resimden 1.
    • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
    • Rubber tabs will require force to access screws.
  3. HP 17-bs049dx Back Panel Replacement: adım 3, 1 resimden 1.
    • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
  4. HP 17-bs049dx Back Panel Replacement: adım 4, 2 resimden 1. HP 17-bs049dx Back Panel Replacement: adım 4, 2 resimden 2.
    • Pull outwards on the disk reader to remove from main frame.
    • This removal will require force.
    • All screws must be removed before removing disk reader.
  5. HP 17-bs049dx Back Panel Replacement: adım 5, 1 resimden 1.
    • Lift back panel to access internal components.
    • You will need to use force to pry it open.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Megan Paige
475 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 41
Her zaman: 1,777
