Ana içeriğe geç
Parçalar
Hiçbir parça belirtilmedi.
  1. Flip the laptop so you can see the serial number and the four 7mm screws in all the corners. Click the hinges by pushing them inward, which are located at the top. Remove the battery by pulling it out.
    • Flip the laptop so you can see the serial number and the four 7mm screws in all the corners.
    • Click the hinges by pushing them inward, which are located at the top.
    • Remove the battery by pulling it out.
  2. Remove the 2 pieces of black tape that are each covering a 7mm screw at the top corners of the laptop. When removing the 2 black pieces of tape, keep the tape so you can place it back on the laptop again when reassembling. Remove the fourteen 7mm screws with a JIS #00 screwdriver.
    • Remove the 2 pieces of black tape that are each covering a 7mm screw at the top corners of the laptop.
    • When removing the 2 black pieces of tape, keep the tape so you can place it back on the laptop again when reassembling.
    • Remove the fourteen 7mm screws with a JIS #00 screwdriver.
  3. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Lift the bottom cover of the laptop with a metal spudger by wedging the sides first and going all around. The cover is difficult to lift, so use extreme force.
    • Lift the bottom cover of the laptop with a metal spudger by wedging the sides first and going all around.
    • The cover is difficult to lift, so use extreme force.
  5. Carefully pull the two cables attached to the CPU. They are labeled 1 and 2. When putting the cables back, make sure to put them in the correct section. Remove the screw holding down the CPU with the same screwdriver tip as before.
    • Carefully pull the two cables attached to the CPU.
    • They are labeled 1 and 2. When putting the cables back, make sure to put them in the correct section.
    • Remove the screw holding down the CPU with the same screwdriver tip as before.
    • Gently pull on the CPU to remove it.
Sonuç
Tyrin
188 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 4
Her zaman: 89
